1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: weird record names?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Sat, 13 Jun 2020 08:07:32 -0700
On 6/10/20 9:13 AM, Michael Davidsaver wrote:
> On 6/9/20 6:33 PM, Hu, Yong wrote:
>> Michael,
>> When you say "restrictions", does that mean a newer version of EPICS IOC will fail to load a .db file in which a record name contains a "weird" character?
> Eventually, yes.  That is what I'm considering.
cf. for a concrete proposal.  https://github.com/epics-base/epics-base/pull/78
>> If the IOC fails to load .db because it does not follow the new rules/restrictions, facilities that have already used "weird" characters will suffer badly when they upgrade EPICS base to a newer version.
> I recognize and want to avoid this.
> Any new restriction would begin as a warning,
> and likely remain so for a number of years.
> This would mainly serve as an early indication
> of names which would cause problems in other
> contexts.  Record names which would be impossible
> in link to (like "a b" below, or "123"), or which
> would never parse as channel names (like "x.y").
> 3.15.0.1 introduced a warning for record
> names containing " \"'.$".  These might now
> begin to be enforced.  And include "\t" for
> good measure.
>> Yong
>> On 6/8/20, 5:09 PM, "Tech-talk on behalf of Michael Davidsaver via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
>>     I'm looking to collect examples of epics record names in the wild.
>>     This is an early step towards (maybe) adding restrictions on what
>>     characters a record name can contain, and in what positions.
>>     eg. restricting possible first and last characters.
>>     In particular I'm looking for examples including characters
>>     beyond the usual alphanumeric separated by ':' or '-'.
>>     And in what positions they may (or may not) appear.
>>     An example from the NSLS2 naming convention (for which I am have
>>     some responsibility).
>>     > TST{evm:1D-DlyGen:31}Evt:Trig2-SP
>>     Which is notable for containing "{" and "}" in the middle.
>>     As background.  At present, records can be created with almost
>>     any characters in a name.
>>     > record(ai, "a b") {}
>>     > record(ai, "x.y") {}
>>     > record(ai, "x\"") {}
>>     However, record names including '.' can't be addressed and aren't
>>     very useful.  Further, names including spaces can't be targeted
>>     by links.
>>     On the subject of links.  Dirk was surprised to find that
>>     the syntax for link parsing treats "[0]" as a record name,
>>     but "[0,1]" as a constant array.
>>     https://urldefense.com/v3/__https://bugs.launchpad.net/epics-base/*bug/1882520__;Kw!!P4SdNyxKAPE!TwNJ4RpksYZmN8YbfgjiN7Y3igc4486VOLcj-_1L1KUqPcMdbvxVXH_bSrI3$
>>     Rather than carving out another exception, I'd like to look at
>>     coding a general rule.
weird record names? Michael Davidsaver via Tech-talk
Re: weird record names? Hu, Yong via Tech-talk
Re: weird record names? Michael Davidsaver via Tech-talk
Prev: Re: weird record names? Faucett, John Allen via Tech-talk
Next: How to run IOC in docker containers properly xiao zhang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: weird record names? Michael Davidsaver via Tech-talk
Next: Re: weird record names? Konrad, Martin via Tech-talk
