1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How to run IOC in docker containers properly
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 15 Jun 2020 09:32:50 +0200
Hey Xiao,
we are using Docker containers for our IOCs as well. We start the container with the "-dit" options. The additional "-it" creates an interactive TTY which keeps the iocsh alive within the container. Also with this option you can "enter" the container and work with the iocsh by using the command:
`docker attach <container id>`
Leave the iocsh with `CTRL+p CTRL+q`
HTH Florian
Am 15.06.2020 um 09:23 schrieb xiao zhang via Tech-talk:
Hi all,
The only way of starting an IOC I have learned is by running the `st.cmd` script, which by default opens an iocsh shell on success. I am seeing 2 problems when running IOCs in containers:
1. The iocsh shell seems redundant as nobody will actually use it when run in containers. A way to start IOC which does not open up iocsh is a more light-weight solution. 2. When running an IOC container with `-d` option only, the container stops immediately. A dirty workaround is using `-it` option to attach a pseudo-tty to the container. The caveat is that when the IOC is broken the container keeps running. Although a liveliness probe can be used to check the health condition of the IOC, a container exiting when the IOC is broken is certainly a more light-weight and reliable solution.
TL;DR, is there a proper way to start a persistent iocsh-less IOC instance?
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
How to run IOC in docker containers properly xiao zhang via Tech-talk
Prev: How to run IOC in docker containers properly xiao zhang via Tech-talk
Next: Re: Re: How to run IOC in docker containers properly xiao zhang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
