1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How to run IOC in docker containers properly
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: xiao zhang <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 15 Jun 2020 17:43:24 +0000
On Jun 15, 2020, at 2:23 AM, xiao zhang via Tech-talk <[email protected]> wrote:
The only way of starting an IOC I have learned is by running the `st.cmd` script, which by default opens an iocsh shell on success. I am seeing 2 problems when running IOCs in containers:
1. The iocsh shell seems redundant as nobody will actually use it when run in containers. A way to start IOC which does not open up iocsh is a more light-weight solution.
I can’t help you with the container side at all, but it is possible to build an IOC that doesn’t start the IOC shell, or if you’re using one of the softIoc executables, tell that to not start the shell. In both cases though the IOC keeps its stdin, stdout and stderr streams open, and it will continue to send messages to stdout/stderr.
If you’re building your own application binary, you have to edit your <app>App/src/<app>Main.cpp file, remove the line iocsh(NULL) and replace the call to epicsExit(0) with a call to epicsThreadExitMain().
If you’re running the softIoc or softIocPVA executable from Base, you can pass that the flag -S (that’s an upper-case letter ’s’ to do the same thing as the above.
The result isn’t really any lighter-weight from the IOC’s perspective though, it just means you will have no ability to interact with the IOC while it’s running except through CA (or PVA). You can’t close stdin, send Control-C through it or use kill -QUIT to stop it, you have to use a kill -9 (SIGKILL) to make it die.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Prev: Re: ci-scripts 3.0 release: Windows on Travis Torsten Bögershausen via Tech-talk
Next: Re: How to run IOC in docker containers properly xiao zhang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: How to run IOC in docker containers properly Florian Feldbauer via Tech-talk
