Subject: Re: How to run IOC in docker containers properly
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 16 Jun 2020 13:01:17 +0800
Hi
Thanks for the suggestions. The epicsThreadExitMain() did the trick for me. No significant memory usage reduction was seen in the shell-less IOC. You are right.
On Tue, 16 Jun 2020 at 01:43, Johnson, Andrew N. <[email protected]> wrote:
On Jun 15, 2020, at 2:23 AM, xiao zhang via Tech-talk <[email protected]> wrote:
The only way of starting an IOC I have learned is by running the `st.cmd` script, which by default opens an iocsh shell on success. I am seeing 2 problems when running IOCs in containers:
1. The iocsh shell seems redundant as nobody will actually use it when run in containers. A way to start IOC which does not open up iocsh is a more light-weight solution.
I can’t help you with the container side at all, but it is possible to build an IOC that doesn’t start the IOC shell, or if you’re using one of the softIoc executables, tell that to not start the shell. In both cases though the IOC keeps its stdin, stdout and stderr streams open, and it will continue to send messages to stdout/stderr.
If you’re building your own application binary, you have to edit your <app>App/src/<app>Main.cpp file, remove the line iocsh(NULL) and replace the call to epicsExit(0) with a call to epicsThreadExitMain().
If you’re running the softIoc or softIocPVA executable from Base, you can pass that the flag -S (that’s an upper-case letter ’s’ to do the same thing as the above.
The result isn’t really any lighter-weight from the IOC’s perspective though, it just means you will have no ability to interact with the IOC while it’s running except through CA (or PVA). You can’t close stdin, send Control-C through it or use kill -QUIT to stop it, you have to use a kill -9 (SIGKILL) to make it die.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Prev: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Next: Re: Lexium MDrive Ethernet Dr. Bastian Löher via Tech-talk
Next: Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
