Hi
Thanks for the hint. Using `CMD ./st.cmd` as the entry point makes the container work as desired.
Hey,
to the caveats:
1) I agree, entering the iocsh is not part of a normal workflow. We only
enter the interactive shell of the container for debugging. In normal
operation the shell is detached and not used. So there is not really an
overhead.
2) I cannot confirm this behaviour. In our cases, when the ioc breaks
the container exits. Which command are you using within you container?
In our case the command which is started inside the container is simply
`st.cmd`. So if the IOC breaks, the command of the container is finished
and thus the container stops.
Best regards,
Florian
Am 15.06.2020 um 10:03 schrieb xiao zhang via Tech-talk:
> Hi Florian
> Thanks for sharing your experience. But I am not satisfied with the
> way it has to be.
> As mentioned in my original post, the current method has 2 caveats:
> 1. Unnecessary overhead as entering the interactive shell of a running
> container is not part of a normal workflow
> 2. The container does not exit when the IOC process breaks
> An iocsh-less way to start IOC solves both the above concerns as only
> `-d` option is required in this case. When the IOC process breaks, the
> container will exit immediately and tell the outer world that it is
> broken, so that a restart can be scheduled either manually or by an
> automatic container orchestrator.
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone: (+49)234 / 32-23563
Fax: (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
- Re: Re: How to run IOC in docker containers properly xiao zhang via Tech-talk
- Re: How to run IOC in docker containers properly Florian Feldbauer via Tech-talk
ci-scripts 3.0 release: Windows on Travis Ralph Lange via Tech-talk
<2020>
2025
2026
Re: How to run IOC in docker containers properly Ryan Slominski via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
