Subject: Re: IOC Startup - init value used sometimes instead of put
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Paul Nord <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 16 Jun 2020 15:17:26 -0500
On 06/16, Paul Nord via Tech-talk wrote:
> Strange problem.
> A. I create a bunch of PV's with initial values.
> B. A little later in the code another configuration file is read for values
> and put is called.
> C. IOC is started.
> D. Some of the PV's get the correct values.  Some still show init value.
> If I call the configure routine to set the PV's "some time" later, the load
> reliability.
> I can add a 30 second delay, but I've lost confidence that I can
> guarantee initialization under circumstances where processor load might
> change.  It looks like the "init" value is being set some random time after
> the PV is created.  Possibly even overwriting later calls to put.
> I'm using Python Soft IOC.
> Thoughts?
Where is iocInit called in your A-D sequence?  Are CA links involved?
Possibly related to this?
  https://epics.anl.gov/tech-talk/2012/msg02082.php
Lewis
IOC Startup - init value used sometimes instead of put Paul Nord via Tech-talk
Prev: Re: IOC Startup - init value used sometimes instead of put Mark Rivers via Tech-talk
Next: Re: IOC Startup - init value used sometimes instead of put Paul Nord via Tech-talk
Prev: RE: IOC Startup - init value used sometimes instead of put Mark Rivers via Tech-talk
Next: No PV record found when build ASYN application on Windows shenzb--- via Tech-talk
