1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: tsub record: assert(prt->no_fields == 558) fails
From: John Dobbins via Tech-talk <[email protected]>
Date: Wed, 17 Jun 2020 16:07:32 +0000
I find that the tpmac-master from github has two different tsubRecord.dbd
./pmacApp/src/tsubRecord.dbd
./pmacApp/tsubSrc/tsubRecord.dbd
differing by the addition of the STYP field.
Is this intentional?
John
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Tuesday, June 16, 2020 12:03 PM
To: [email protected] <[email protected]>
Subject: tsub record: assert(prt->no_fields == 558) fails
All,
I am trying to add the tsub record from TPMAC to an IOC.
Everything builds without trouble but when I run the IOC I get an assert failure for number of fields in the tsub record, see console output below.
This is linux-x86_64, using base 7.0.3, asyn-R4-38, motor-R7-1
Downloaded tpmac-master from
BTW, I did poke around enough to realize I didn't know if 'prt->no_fields' is supposed to be the number of fields or the index of the last field. If I count the tsub record fields in my jbiTest.dbd I get 559.
Hoping you can help me figure out where I went astray.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
jad22@lnx615 $ ../../bin/linux-x86_64/jbiTest st.cmd
#!../../bin/linux-x86_64/jbiTest
< envPaths
epicsEnvSet("IOC","iocjbiTest")
epicsEnvSet("TOP","/nfs/chess/user/jad22/JBluIce/epics/jbiTest")
epicsEnvSet("TPMAC","/nfs/chess/user/jad22/epics/support/tpmac")
epicsEnvSet("EPICS_BASE","/nfs/chess/epics/release/base/base-7.0.2")
dbLoadDatabase("../../dbd/jbiTest.dbd",0,0)
jbiTest_registerRecordDeviceDriver(pdbbase)
A call to 'assert(prt->no_fields == 558)'
    by thread '_main_' failed in ../O.Common/tsubRecord.h line 1145.
Dumping a stack trace of thread '_main_':
[          0x51447b]: ../../bin/linux-x86_64/jbiTest(epicsStackTrace+0x4b)
[          0x50ff8a]: ../../bin/linux-x86_64/jbiTest(epicsAssert+0x3a)
[          0x439c0b]: ../../bin/linux-x86_64/jbiTest(tsubRecordSizeOffset+0x3b)
[          0x4bcae8]: ../../bin/linux-x86_64/jbiTest(registerRecordTypes+0xc8)
[          0x439880]: ../../bin/linux-x86_64/jbiTest(jbiTest_registerRecordDeviceDriver+0x60)
[          0x5026b5]: ../../bin/linux-x86_64/jbiTest(iocshBody+0xb15)
[          0x439552]: ../../bin/linux-x86_64/jbiTest(main+0x12)
[    0x7f0bc7507545]: /lib64/libc.so.6(__libc_start_main+0xf5)
[          0x439752]: ../../bin/linux-x86_64/jbiTest(_start+0x29)
EPICS Release EPICS R7.0.2.
Local time is 2020-06-16 11:47:22.592146284 EDT
Please E-mail this message to the author or to [email protected]
tsub record: assert(prt->no_fields == 558) fails John Dobbins via Tech-talk
Prev: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Next: EPICS Records at Runtime Mostafa, Jalal (IPE) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: tsub record: assert(prt->no_fields == 558) fails Johnson, Andrew N. via Tech-talk
Next: IOC Startup - init value used sometimes instead of put Paul Nord via Tech-talk
