1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: question about monitering pv by using jcae
To: [email protected]
Date: Tue, 30 Jun 2020 09:00:48 +0800 (GMT+08:00)
Dear all:
 I use jcae to monitor 100 PVs of softIoc。 All theses pv value equals a specific pv named trigger plus a constant , and set SCAN=0.1s. To make sure all pv changes every 0.1s, I use pyepics to put a new value to the trigger pv every 0.1s . In my readout program,I monitor all 100 PVs.
Every 1000s , I calculate all 100 pv update times. Ideally , every 1000s the update times is 100*1000*10. But i only get 999932., which means there are0.0068% update data lost. Then I only montor 50 PVs, this time i get all update data . When I monitor 3000 PVs, the lost ratio is 0.095%.
  Is that means in one ioc database , if i want get all update data , I only can monitor 50 PVs? Or i don't do the test right?
  When number of pv is growing, is it normal to lost update data?
Re: question about monitering pv by using jcae Ralph Lange via Tech-talk
Prev: Re: Sub record not finding INAM and SNAM Ernesto Paiser via Tech-talk
Next: Re: question about monitering pv by using jcae Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: ci-scripts 3.1 release: support for GitHub Actions Ralph Lange via Tech-talk
