This is a bug. Would you like to create a report?
https://github.com/epics-base/pva2pva/
On 7/1/20 2:46 PM, Saeed via Tech-talk wrote:
> Hi,
> I'm trying to use DISP field for disabling the remote puts to my PV. It works as expected when I use CA but it seems like the IOC is neglecting this field and actually write to PV when the put is issued from pvAccess.
> 'test' is an ao record without any fields set in DCT and I use EPICS R7.0.4 here.
> ❯ caput test 10
> Old : test 0
> New : test 10
> ❯ pvput test.DISP 1
> Old : 2020-07-01 23:25:09.008 0
> New : 2020-07-01 23:25:09.008 1
> ❯ caput test 20
> Old : test 10
> CA.Client.Exception...............................................
> Warning: "Channel write request failed"
> Context: "op=1, channel=test, type=DBR_STRING, count=1, ctx="test""
> Source File: ../oldChannelNotify.cpp line 158
> Current Time: Wed Jul 01 2020 23:25:34.720217912
> New : test 10
> ❯ pvput test 20
> Old : 2020-07-01 23:25:09.008 10
> New : 2020-07-01 23:25:42.116 20
> Any thoughts?
> Thanks,
> Saeed
- DISP field in pvAccess Saeed via Tech-talk
- Re: DISP field in pvAccess Michael Davidsaver via Tech-talk
FW: Opening opi/bob files into display mode from the terminal Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
<2020>
2025
2026
Many EPICS Applications in Docker Images Philipp Klaus via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
