1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Cross-compile epics applicaton for debian 8 on the zynq
To: [email protected]
Date: Sat, 4 Jul 2020 00:31:28 +0800 (GMT+08:00)
Hello,
     Although  cross-compiled successfully the base-3.14.12.8, synApps_5_8 and soft IOC example which work well on my target now,  I need  help to cross-compile another EPICS application ,named ramp, compiled no problem on the x86_64 host computer. My device  is the zynq of Xilinx with debian 8,  and the ramp is to control the serial and  TCP/IP device , it consists of these components:
SUPPORT=/home/zj/zlinx/synApps_5_8/support
ASYN=$(SUPPORT)/asyn-4-26
CALC=$(SUPPORT)/calc-3-4-2-1
STREAM=$(SUPPORT)/stream-2-6a
SNCSEQ=$(SUPPORT)/seq-2-2-1
PCRE_INCLUDE=/usr/include
PCRE_LIB=/usr/lib
Here is the output of make, It seems that the compiler can't find file 'librampSupport.so', in fact the file exists,however I really don't know what to do now, I appreciate it if you could give any advice. thanks!
make -C ./configure install
make[1]: Entering directory '/home/zj/zlinx/zynq-epics-proj/ramp/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/zj/zlinx/zynq-epics-proj/ramp/configure/O.linux-x86_64'
perl /home/zj/zlinx/base-3.14.12.8/bin/linux-x86_64/convertRelease.pl checkRelease
EPICS/Release.pm: Undefined macro $(AREA_DETECTOR) used
make[2]: Leaving directory '/home/zj/zlinx/zynq-epics-proj/ramp/configure/O.linux-x86_64'
make -C O.linux-arm -f ../Makefile TOP=../.. \
    T_A=linux-arm install
make[2]: Entering directory '/home/zj/zlinx/zynq-epics-proj/ramp/configure/O.linux-arm'
make[2]: Leaving directory '/home/zj/zlinx/zynq-epics-proj/ramp/configure/O.linux-arm'
make[1]: Leaving directory '/home/zj/zlinx/zynq-epics-proj/ramp/configure'
make -C ./rampApp install
make[1]: Entering directory '/home/zj/zlinx/zynq-epics-proj/ramp/rampApp'
make -C ./src install
make[2]: Entering directory '/home/zj/zlinx/zynq-epics-proj/ramp/rampApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/home/zj/zlinx/zynq-epics-proj/ramp/rampApp/src/O.linux-x86_64'
/usr/bin/gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/zj/zlinx/base-3.14.12.8/include/os/Linux -I/home/zj/zlinx/base-3.14.12.8/include    -I/home/zj/zlinx/synApps_5_8/support/asyn-4-26/include  -I/home/zj/zlinx/synApps_5_8/support/calc-3-4-2-1/include  -I/home/zj/zlinx/synApps_5_8/support/stream-2-6a/include  -I/home/zj/zlinx/synApps_5_8/support/seq-2-2-1/include            ../xxxRecord.c
/usr/bin/gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/zj/zlinx/base-3.14.12.8/include/os/Linux -I/home/zj/zlinx/base-3.14.12.8/include    -I/home/zj/zlinx/synApps_5_8/support/asyn-4-26/include  -I/home/zj/zlinx/synApps_5_8/support/calc-3-4-2-1/include  -I/home/zj/zlinx/synApps_5_8/support/stream-2-6a/include  -I/home/zj/zlinx/synApps_5_8/support/seq-2-2-1/include            ../devXxxSoft.c
/usr/bin/gcc -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall       -m64     -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/zj/zlinx/base-3.14.12.8/include/os/Linux -I/home/zj/zlinx/base-3.14.12.8/include    -I/home/zj/zlinx/synApps_5_8/support/asyn-4-26/include  -I/home/zj/zlinx/synApps_5_8/support/calc-3-4-2-1/include  -I/home/zj/zlinx/synApps_5_8/support/stream-2-6a/include  -I/home/zj/zlinx/synApps_5_8/support/seq-2-2-1/include            ../dbSubExample.c
/usr/bin/ar -rc    librampSupport.a        xxxRecord.o devXxxSoft.o dbSubExample.o rampHello.o initTrace.o sncExample.o
/usr/bin/ranlib librampSupport.a
Installing library ../../../lib/linux-x86_64/librampSupport.a
/usr/bin/g++ -o sncProgram -Wl,-Bstatic -L/home/zj/zlinx/base-3.14.12.8/lib/linux-x86_64 -L/home/zj/zlinx/synApps_5_8/support/seq-2-2-1/lib/linux-x86_64         -m64               sncProgram.o    -lseq -lpv -lcas -lgdd -lasHost -ldbStaticHost -lregistryIoc -lca -lCom -Wl,-Bdynamic  -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing Tcl library ../../../lib/linux-x86_64/librampSupport.so
Usage:
     [ -m mode ] file ... directory
    -d             Create non-existing directories
    -m mode        Set the mode for the installed file (0755 by default)
    file           Name of file
    directory      Destination directory
Can't find file 'librampSupport.so'
/home/zj/zlinx/base-3.14.12.8/configure/RULES_BUILD:445: recipe for target '../../../lib/linux-x86_64/librampSupport.so' failed
make[3]: *** [../../../lib/linux-x86_64/librampSupport.so] Error 2
make[3]: Leaving directory '/home/zj/zlinx/zynq-epics-proj/ramp/rampApp/src/O.linux-x86_64'
/home/zj/zlinx/base-3.14.12.8/configure/RULES_ARCHS:61: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/zj/zlinx/zynq-epics-proj/ramp/rampApp/src'
/home/zj/zlinx/base-3.14.12.8/configure/RULES_DIRS:83: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/home/zj/zlinx/zynq-epics-proj/ramp/rampApp'
/home/zj/zlinx/base-3.14.12.8/configure/RULES_DIRS:83: recipe for target 'rampApp.install' failed
make: *** [rampApp.install] Error 2
RE: Cross-compile epics applicaton for debian 8 on the zynq Mark Rivers via Tech-talk
Prev: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
Next: RE: Cross-compile epics applicaton for debian 8 on the zynq Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: how to acess variables in record field. Mark Rivers via Tech-talk
