1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [PV Access] Decimation Channel filter equivalent for PV Access?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Juan F. Esteban Müller <[email protected]>
Date: Fri, 3 Jul 2020 07:46:47 -0700
On 7/1/20 11:21 AM, Juan F. Esteban Müller wrote:
> Thanks for the info. I don't fully understand the issue... Is there any workaround? Or in which cases the "dec" filter works?
I may have a fix.  Please test if you are able.
https://github.com/epics-base/pva2pva/pull/34
> Cheers,
> Juan
> On 2020-07-01, 18:22, "Michael Davidsaver" <[email protected]> wrote:
>     On 7/1/20 9:09 AM, Juan F. Esteban Müller wrote:
>     > Hi Michael,
>     > Thanks for your reply.
>     > I was suspicious, because I had the feeling I used it in the past... Can you maybe then give me a clue why I can't make it work in a simple example?
>     > This is my db file:
>     > record(calc, "Test:counter") {
>     >     field(INPA, " Test:counter")
>     >     field(CALC, "A+1")
>     >     field(SCAN, "1 second")
>     > And I run it using softIocPVA.
>     > If I do
>     > camonitor 'Test:counter.{"dec":{"n":2}}'
>     > I get every second update, while if I do
>     > pvmonitor 'Test:counter.{"dec":{"n":2}}'
>     > I get nothing. Funny enough, if I do
>     > pvmonitor 'Test:counter.{"dec":{"n":1}}'
>     > then I get every update...
>     > I am using base 7.0.4, but I also tested 7.0.3.1, which is the one I used in the past when testing the filters.
>     Oh, right.  With the 'dec' filter you're seeing the effects of:
>     https://github.com/epics-base/pva2pva/issues/32
>     Specifically:
>     > QSRV assumes that the first DBE_PROPERTY update will never be dropped.
>     > If such an update is dropped, the subscription stalls.
>     I don't have a full solution to this yet.
>     Part of https://github.com/epics-base/epics-base/pull/71
>     includes a change to Base which will allow filters to distinguish
>     value and meta-data updates.  Of course this won't necessarily
>     help with older Base versions.
>     QSRV could also be changed to not wait for the initial meta-data
>     update.  The result would be a double initial update for most new subscribers.
>     There is nothing really wrong with this, I just found it annoying.
>     > Cheers,
>     > Juan
>     > On 2020-07-01, 15:39, "Michael Davidsaver" <[email protected]> wrote:
>     >     On 7/1/20 2:59 AM, Juan F. Esteban Müller via Tech-talk wrote:
>     >     > Hi all,
>     >     > I would like to know if there is anything equivalent to the CA decimation filter in PV access.
>     >     > https://epics.anl.gov/base/R7-0/4-docs/filters.html#Decimation-Filter-dec
>     >     These filters are implemented at the database level, and so work both with CA and PVA
>     >     (via. the RSRV and QSRV server implementations).
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
Prev: how to acess variables in record field. Saurabh Srivastava via Tech-talk
Next: Cross-compile epics applicaton for debian 8 on the zynq 赵江 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Next: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
