Subject: Re: [PV Access] Decimation Channel filter equivalent for PV Access?
From: Juan F. Esteban Müller via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 1 Jul 2020 18:21:51 +0000
Thanks for the info. I don't fully understand the issue... Is there any workaround? Or in which cases the "dec" filter works?
Cheers,
Juan
On 2020-07-01, 18:22, "Michael Davidsaver" <[email protected]> wrote:
    On 7/1/20 9:09 AM, Juan F. Esteban Müller wrote:
    > Hi Michael,
    > Thanks for your reply.
    > I was suspicious, because I had the feeling I used it in the past... Can you maybe then give me a clue why I can't make it work in a simple example?
    > This is my db file:
    > record(calc, "Test:counter") {
    >     field(INPA, " Test:counter")
    >     field(CALC, "A+1")
    >     field(SCAN, "1 second")
    > And I run it using softIocPVA.
    > If I do
    > camonitor 'Test:counter.{"dec":{"n":2}}'
    > I get every second update, while if I do
    > pvmonitor 'Test:counter.{"dec":{"n":2}}'
    > I get nothing. Funny enough, if I do
    > pvmonitor 'Test:counter.{"dec":{"n":1}}'
    > then I get every update...
    > I am using base 7.0.4, but I also tested 7.0.3.1, which is the one I used in the past when testing the filters.
    Oh, right.  With the 'dec' filter you're seeing the effects of:
    https://github.com/epics-base/pva2pva/issues/32
    Specifically:
    > QSRV assumes that the first DBE_PROPERTY update will never be dropped.
    > If such an update is dropped, the subscription stalls.
    I don't have a full solution to this yet.
    Part of https://github.com/epics-base/epics-base/pull/71
    includes a change to Base which will allow filters to distinguish
    value and meta-data updates.  Of course this won't necessarily
    help with older Base versions.
    QSRV could also be changed to not wait for the initial meta-data
    update.  The result would be a double initial update for most new subscribers.
    There is nothing really wrong with this, I just found it annoying.
    > Cheers,
    > Juan
    > On 2020-07-01, 15:39, "Michael Davidsaver" <[email protected]> wrote:
    >     On 7/1/20 2:59 AM, Juan F. Esteban Müller via Tech-talk wrote:
    >     > Hi all,
    >     > I would like to know if there is anything equivalent to the CA decimation filter in PV access.
    >     > https://epics.anl.gov/base/R7-0/4-docs/filters.html#Decimation-Filter-dec
    >     These filters are implemented at the database level, and so work both with CA and PVA
    >     (via. the RSRV and QSRV server implementations).
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
[PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Prev: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
Next: ARM cross-built targets linux-arm_el and linux-arm_eb – last call Johnson, Andrew N. via Tech-talk
Next: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
