Subject: Question about running cs-studio/phoebus with Channel Archiver
From: Elena Malanushenko via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 7 Jul 2020 00:07:46 -0600
Hi all,
I was running previous versions of CSS, and now, when I read about Phoebus, I try it.
It is much better for us.  I run macOS Mojave. Use this document to download, unzip and
setup CSS_Phoebus application.
I  have connected CSS with Live Epics data, and can see realtime data on Data Browser.
I could not connect with Chanel Archiver.    My preferences in settings.ini are the next:
org.csstudio.trends.databrowser3/archives=xnds://localhost:5080/telemetry/cgi/ArchiveDataServer.cgi|tron
org.csstudio.trends.databrowser3/use_default_archives=true
I am getting error when check archiver info, and when trying to make search in Archive Search Panel,  and no data.
The Error is:
Error:
java.io.IOException: Server returned HTTP response code: 400 for URL: http://localhost:5080/telemetry/cgi/ArchiveDataServer.cgi
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1927)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1523)
at org.phoebus.archive.reader.channelarchiver.XmlRpc.communicate(XmlRpc.java:103)
at org.phoebus.archive.reader.channelarchiver.XMLRPCArchiveReader.<init>(XMLRPCArchiveReader.java:71)
at org.phoebus.archive.reader.channelarchiver.XMLRPCArchiveReaderFactory.createReader(XMLRPCArchiveReaderFactory.java:30)
at org.phoebus.archive.reader.ArchiveReaders.createReader(ArchiveReaders.java:46)
at org.csstudio.trends.databrowser3.ui.search.ArchiveListPane.lambda$showArchiveInfo$3(ArchiveListPane.java:75)
at org.phoebus.framework.jobs.Job.execute(Job.java:50)
at org.phoebus.framework.jobs.JobManager.execute(JobManager.java:54)
at org.phoebus.framework.jobs.JobManager.lambda$schedule$0(JobManager.java:45)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1130)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:630)
at java.base/java.lang.Thread.run(Thread.java:832)
At the same time, sunning old CSS 3.16, I am getting archived data in Data Browser.
Could you please suggest me where I am going wrong, and how to fix this.
Thank you so much for any help !
Olena Malanushenko
Apache Point Observatory, NM
Prev: HiSLIP support(experimental) for asy/stream device. Noboru Yamamoto via Tech-talk
Next: Array PV doesn't update in CSS BOY Adrian Martinez via Tech-talk
Prev: RE: HiSLIP support(experimental) for asy/stream device. Mark Rivers via Tech-talk
