Hi, I have an Asyn driver and one of the PV (asynInt32ArrayIn) doesn't update in CSS BOY. If you run the opi, the PV gets values but never update them again ( unless the opi is updated) . I attach the PV in .db file: record(waveform, "$(user):DInILKArrayPreRdbk") { field(DTYP, "asynInt32ArrayIn") field(INP ,"@asyn($(PORT),$(ADDR),$(TIMEOUT))DInILKArrayPre") field(SCAN ,"I/O Intr") field(FTVL, "ULONG") field(NELM, "512") field(PINI, "YES") field(DESC ,"Interlock status array") } This PV is used by a widget, which runs a script, being my PV an 'input PV'. Can anyone help me with this? Thanks, Adrián. This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
