1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Array PV doesn't update in CSS BOY
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>, Adrian Martinez <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 7 Jul 2020 15:51:34 +0000
Adrian,
It seems that the value of PV does not change, which could result in no plot change in CSS OPI.
Like Mark pointed out, you might want to check your driver in that case.
An easy way is to use camonitor to confirm whether the array value of your PV updates as you are expecting.
Guobao
On 7/7/20, 10:32 AM, "Tech-talk on behalf of Mark Rivers via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    Hi Adrian,
    One simple explanation for what you are seeing would be that your driver is not calling the following:
    doCallbacksInt32Array(value, nElements, reason, addr)
    If your driver does not call that function when the array changes then records with SCAN=I/O Intr will not update.
    From: Tech-talk <[email protected]> on behalf of Adrian Martinez via Tech-talk <[email protected]>
    Sent: Tuesday, July 7, 2020 5:17 AM
    To: [email protected]
    Subject: Array PV doesn't update in CSS BOY
    Hi, I have an Asyn driver and one of the PV (asynInt32ArrayIn) doesn't update in CSS BOY.
    If you run the opi, the PV gets values but never update them again ( unless the opi is updated) .
    I attach the PV in .db file:
    record(waveform, "$(user):DInILKArrayPreRdbk")
    field(DTYP, "asynInt32ArrayIn")
    field(INP  ,"@asyn($(PORT),$(ADDR),$(TIMEOUT))DInILKArrayPre")
    field(SCAN ,"I/O Intr")
    field(FTVL, "ULONG")
    field(NELM, "512")
    field(PINI, "YES")
    field(DESC ,"Interlock status array")
    This PV is used by a widget, which runs a script, being my PV an 'input PV'.
    Can anyone help me with this?
    Thanks, Adrián.
     This e-mail and any materials attached hereto, including, without limitation, all content hereof and thereof are confidential and proprietary to Seven Solutions,S.L and/or its affiliates, and are *confidential*. Without the prior written consent of Seven Solutions, this content may not (i) be disclosed to any third party, (ii) be reproduced, modified or otherwise used by anyone other than current employees of Seven Solutions or its affiliates. If you are not the intended recipient or if this message has been received in error, please notify us immediately via e-mail and delete it.
Array PV doesn't update in CSS BOY Adrian Martinez via Tech-talk
Re: Array PV doesn't update in CSS BOY Mark Rivers via Tech-talk
Prev: Re: Array PV doesn't update in CSS BOY Mark Rivers via Tech-talk
Next: How to resolve CA beacon routing error messages when rebooting IOC is not helping Tang, Johnny via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Bug Text Input (Selector Type: file) CSS BOY Adrian Martinez via Tech-talk
