1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: dbdExpand.pl: Duplicate definition of record type 'asyn'
Date: Thu, 9 Jul 2020 22:05:09 +0000
Hi Mark,
As you know, I have trouble with hp3458a which is using very old asyn & StreamDevice. So I am trying to rebuild the hp3458a IOC.
I git clone the latest asyn from GitHub (commit 07f52d99f1977b76191dda505cf9d24b90548743). Firstly I tried to compile it on Debian-7 (wheezy) against base-3.14.12.3 which is pre-installed on our Debian-7 servers. However, it failed: ../../asyn/drvAsynSerial/drvAsynIPPort.c:467:21: error: ‘O_REUSEPORT’ undeclared (first use in this function).
A little google search indicates this might be related to Debian 7’s old kernel or system library. So, I moved to a newer server with Debian-9 (stretch) and built the latest asyn and the latest StreamDevice successfully against base-3.15.6 which is pre-installed on our Debian-9 servers.
When I try to rebuild the hp3458a IOC against the latest asyn & StreamDevice, it fails:
Creating dbd file hp3458a.dbd
perl -CSD /home/yhu/src/base-3.15.6/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/home/yhu/src/asyn/dbd -I/home/yhu/src/StreamDevice/dbd -I/home/yhu/src/base-3.15.6/dbd -o hp3458a.dbd base.dbd xxxSupport.dbd dbSubExample.dbd hp3458aHello.dbd initTrace.dbd devHP3458A.dbd system.dbd asyn.dbd stream.dbd drvVxi11.dbd
Context: recordtype(asyn) in file '/home/yhu/src/asyn/dbd/asynRecord.dbd' in file '/home/yhu/src/asyn/dbd/asyn.dbd'
  while reading 'asyn.dbd' to create 'hp3458a.dbd'
dbdExpand.pl: Exiting due to errors
What is the best way to fix this problem?
Yong
Prev: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
Next: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: AW: Integrating picoscopes into the EPICS control system Loeher, Bastian Dr. via Tech-talk
Next: Re: dbdExpand.pl: Duplicate definition of record type 'asyn' Mark Rivers via Tech-talk
