Subject: Re: Long String support in phoebus
From: "Nonn, Patrick via Tech-talk" <[email protected]>
Date: Fri, 10 Jul 2020 14:08:30 +0200 (CEST)
Using caput does the same, using caput -S fails with "Error from put operation: Invalid element count requested".
----- Original Message -----
To: "Patrick Nonn" <[email protected]>
Cc: "tech-talk" <[email protected]>
Sent: Friday, 10 July, 2020 14:05:41
What happens if you use caput?
From: Tech-talk <[email protected]> on behalf of Nonn, Patrick via Tech-talk <[email protected]>
Sent: Friday, July 10, 2020 6:57 AM
To: tech-talk
Subject: Long String support in phoebus
Hi everyone,
I try to write an lso record with a text entry widget. The string is cut at 40 characters. Is there something to be taken into account, apart from:
preference "org.phoebus.pv.ca/max_array_bytes" set to a high enough number
field SIZV set to a high enough number
Greetings
Patrick
Re: Long String support in phoebus Ralph Lange via Tech-talk
Re: Long String support in phoebus Mark Rivers via Tech-talk
Long String support in phoebus Nonn, Patrick via Tech-talk
Prev: Re: Long String support in phoebus Mark Rivers via Tech-talk
Next: Re: Long String support in phoebus Ralph Lange via Tech-talk
