1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Long String support in phoebus
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 10 Jul 2020 15:28:57 +0200
On Fri, 10 Jul 2020 at 14:09, Nonn, Patrick via Tech-talk <[email protected]> wrote:
Using caput does the same, using caput -S fails with "Error from put operation: Invalid element count requested".
You are using the '$' at the PV name that shows the IOC you want to treat the field as array of char (instead of string)?
Long String support in phoebus Nonn, Patrick via Tech-talk
Re: Long String support in phoebus Mark Rivers via Tech-talk
Re: Long String support in phoebus Nonn, Patrick via Tech-talk
Prev: Re: Long String support in phoebus Nonn, Patrick via Tech-talk
Next: Re: Long String support in phoebus Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
