Subject: Re: Long String support in phoebus
To: Ralph Lange <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 10 Jul 2020 15:41:05 +0000
Hi Ralph,
Thanks for the clear explanation!
> 2. The server must be told to show fields that are supposed to be long strings as arrays of char to Channel Access. This is a data type issue on the server side, and done by adding the '$' to the PV name.
Can you point me to where this is documented?  The only place I have been able to find it is in the 3.14 Release Notes: https://epics.anl.gov/base/R3-14/12-docs/RELEASE_NOTES.html
It cannot find it in a reference document, i.e.
- Application Developer's Guide 3.16.2 https://epics.anl.gov/base/R3-16/2-docs/AppDevGuide.pdf
- Channel Access Reference Manual https://epics.anl.gov/base/R7-0/4-docs/CAref.html
<https://epics.anl.gov/base/R7-0/4-docs/CAref.html>- Channel Filters https://epics.anl.gov/base/R7-0/4-docs/filters.html
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk <[email protected]>
Sent: Friday, July 10, 2020 8:54 AM
To: EPICS Tech Talk
On Fri, 10 Jul 2020 at 15:34, Mark Rivers via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
It would probably be good to mention that the .VAL$ syntax is required in the lso record documentation here:
https://epics.anl.gov/base/R7-0/4-docs/lsoRecord.html
Actually, there is nothing special about the long string output record.
There are *two* sides to the issue (client and server), and - depending on the field type of the record - there are *two* related switches you may have to activate for long strings to work across Channel Access.
1. The client must be told to send a string as an array of char, and to show an array of char as a string. This is a representation issue on the client side, and done using '-S' with the command line tools.
The waveform record doesn't need the server side switch, because its native data type of the VAL field is already an array of char.
Any string type field that is longer than 40 characters (DESC, link fields, lsi/lso VAL fields, ...) need the '$' switch to be shown as array of char instead of string.
Cheers,
~Ralph
Re: Long String support in phoebus Johnson, Andrew N. via Tech-talk
Long String support in phoebus Nonn, Patrick via Tech-talk
Re: Long String support in phoebus Mark Rivers via Tech-talk
Re: Long String support in phoebus Nonn, Patrick via Tech-talk
Re: Long String support in phoebus Ralph Lange via Tech-talk
Prev: Re: Long String support in phoebus Ralph Lange via Tech-talk
Next: Re: Long String support in phoebus Johnson, Andrew N. via Tech-talk
