Subject: Re: SteamDevice 2.8.x build on Windows issue
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 21 Jul 2020 18:11:07 +0000
EPICS libCom has long defined a set of macros in osiFileName.h to provide these separators. On WIN32:
#define OSI_PATH_LIST_SEPARATOR ";"
#define OSI_PATH_SEPARATOR "\\"
On other OSs that file pulls in unixFileName.h which defines:
#define OSI_PATH_LIST_SEPARATOR ":"
#define OSI_PATH_SEPARATOR "/"
These definitions aren’t direct replacements for Dirk’s char constants since we define them as strings, but it might be possible to write them like this (not tested):
#include <osiFileName.h>
const char pathseparator = *OSI_PATH_LIST_SEPARATOR;
const char dirseparator = *OSI_PATH_SEPARATOR;
- Andrew
On Jul 21, 2020, at 12:43 PM, Mark Rivers via Tech-talk <[email protected]> wrote:
Hi Ralph,
Ø  Doesn't Windows use ';' (semicolon) to separate elements in path variables?
Ø  I would have difficulties parsing this. How does StreamDevice do that?
I was wondering that myself.  Here is the relevant part of the code in StreamProtocol.cc:
#ifdef windows
    const char pathseparator = ';';
    const char dirseparator = '\\';
#else
    const char pathseparator = ':';
    const char dirseparator = '/';
#endif
Note that the code is checking if “windows” is defined.  That seems unusual.  According to the MSVC documentation that is not something their compiler defines:
The next question is whether “windows” is defined on the compiler command line.  This is the output when I build. I added line breaks for clarity, and omitted a bunch of the –I directories.
cl -EHsc -GR
-nologo -FC
-D__STDC__=0
-D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE
-DUSE_TYPED_RSET -DSTREAM_INTERNAL
-Ox -Oy-
-W3 -w44355 -w44344 -w44251
-D_SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING
-MT  -TP
-I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc
-I../../../include/os/WIN32 -I../../../include
-IJ:/epics/devel/include -IH:/epics-devel/base-7.0.4/include/compiler/msvc
-IH:/epics-devel/base-7.0.4/include/os/WIN32 -IH:/epics-devel/base-7.0.4/include
-IJ:/epics/devel/alive-1-1-1/include   -IJ:/epics/devel/allenBradley-2-3/include
-IJ:/epics/devel/tpmac-3-11dls5/include
-IJ:/epics/devel/vac-1-9/include
-IJ:/epics/devel/vme-2-9-2/include
-IJ:/epics/devel/xspress3-2-2/include
I don’t see “windows” being defined there.
I set the iocsh variable streamDebug to 1 and started the IOC.  StreamProtocol will print the full path to the protocol file when it tries to open it in each of the directories in STREAM_PROTOCOL_PATH until it succeeds.  If it cannot find the file it will print an error message.  This is what I see:
2020/07/21 11:44:36.989409 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:187: StreamProtocolParser::readFile: try 'J/LQExcel.proto'
2020/07/21 11:44:36.996306 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:187: StreamProtocolParser::readFile: try '/epics/devel/ip-2-20-1/db/LQExcel.proto'
2020/07/21 11:44:37.005726 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:187: StreamProtocolParser::readFile: try 'J/LQExcel.proto'
2020/07/21 11:44:37.014293 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:187: StreamProtocolParser::readFile: try '/epics/devel/CARS/db/LQExcel.proto'
2020/07/21 11:44:37.024689 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:573: StreamProtocolParser::readToken: Special ' '
2020/07/21 11:44:37.029678 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:265: StreamProtocolParser::parseProtocol: token=' '
2020/07/21 11:44:37.039544 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:579: StreamProtocolParser::readToken: word
2020/07/21 11:44:37.044808 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:590: StreamProtocolParser::readToken: word='on' c=' '
2020/07/21 11:44:37.050567 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:265: StreamProtocolParser::parseProtocol: token='on<00><08><00><00><00>'
2020/07/21 11:44:37.058528 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:763: new Protocol(name="on", line=8)
2020/07/21 11:44:37.063879 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:778: StreamProtocolParser::Protocol::Protocol $0="on"
2020/07/21 11:44:37.069036 win4b28 j:\epics\devel\stream-2-8-14\src\streamprotocol.cc:573: StreamProtocolParser::readToken: Special ' '
It is stripping out the : characters, and using / as the directory separator. So “windows” is clearly not defined and it is using the wrong pathseparator and dirseparator.
But the bizarre thing is that somehow it works!  It is finding LQExcel.proto using this path '/epics/devel/CARS/db/LQExcel.proto’.  That looks very weird, but I just figured out what is happening.  Windows is interpreting that path as an absolute path on the current drive, J:.  Indeed J:/epics/devel/CARS/db/LQExcel.proto is the correct path.
So the answer as to why it works is 2 errors that cancelled, and 1 coincidence!
-          Error #1: StreamDevice is testing the macro “windows” which is not defined so it is using the wrong pathseparator and dirseparator.
-          Error #2: I was using ‘;’ rather than ‘;’ as the path separator.
-          Coincidence: The protocol file happened to be on the current default Windows drive, J:.
I then changed StreamProtocol.cc as follows:
corvette:~/devel/stream/src>git diff .
diff --git a/src/StreamProtocol.cc b/src/StreamProtocol.cc
index 77741b9..a60b6b0 100644
@@ -157,7 +157,7 @@ StreamProtocolParser* StreamProtocolParser::
readFile(const char* filename)
     FILE* file;
-#ifdef windows
+#ifdef _WIN32
#else
Now when I start the IOC still using ‘:’ as the path separator it fails as it should:
epicsEnvSet(STREAM_PROTOCOL_PATH, J:/epics/devel/ip-2-20-1/db:J:/epics/devel/CARS/db)
2020/07/21 12:34:02.309651 win1fe4 j:\epics\devel\stream\src\streamprotocol.cc:187: StreamProtocolParser::readFile: try 'J:/epics/devel/ip-2-20-1/db:J:/epics/devel/CARS/db\LQExcel.proto'
2020/07/21 12:34:02.322569 win1fe4 Can't find readable file 'LQExcel.proto' in 'J:/epics/devel/ip-2-20-1/db:J:/epics/devel/CARS/db'
2020/07/21 12:34:02.329335 win1fe4 while reading protocol 'PowerOut' for '13LQE1:L1PowerOut'
2020/07/21 12:34:02.332623 win1fe4 13LQE1:L1PowerOut: Protocol parse error
2020/07/21 12:34:02.338519 win1fe4 13LQE1:L1PowerOut: Record initialization failed
I then changed the path separator to ‘;’ and now it works correctly:
epicsEnvSet(STREAM_PROTOCOL_PATH, J:/epics/devel/ip-2-20-1/db;J:/epics/devel/CARS/db)
2020/07/21 12:37:38.633552 win3804 j:\epics\devel\stream\src\streamprotocol.cc:187: StreamProtocolParser::readFile: try 'J:/epics/devel/ip-2-20-1/db\LQExcel.proto'
2020/07/21 12:37:38.643656 win3804 j:\epics\devel\stream\src\streamprotocol.cc:187: StreamProtocolParser::readFile: try 'J:/epics/devel/CARS/db\LQExcel.proto'
2020/07/21 12:37:38.668548 win3804 j:\epics\devel\stream\src\streamprotocol.cc:573: StreamProtocolParser::readToken: Special ' '
2020/07/21 12:37:38.675654 win3804 j:\epics\devel\stream\src\streamprotocol.cc:265: StreamProtocolParser::parseProtocol: token=' '
2020/07/21 12:37:38.683407 win3804 j:\epics\devel\stream\src\streamprotocol.cc:579: StreamProtocolParser::readToken: word
2020/07/21 12:37:38.688735 win3804 j:\epics\devel\stream\src\streamprotocol.cc:590: StreamProtocolParser::readToken: word='on' c=' '
2020/07/21 12:37:38.696055 win3804 j:\epics\devel\stream\src\streamprotocol.cc:265: StreamProtocolParser::parseProtocol: token='on<00><08><00><00><00>'
2020/07/21 12:37:38.706280 win3804 j:\epics\devel\stream\src\streamprotocol.cc:763: new Protocol(name="on", line=8)
2020/07/21 12:37:38.713675 win3804 j:\epics\devel\stream\src\streamprotocol.cc:778: StreamProtocolParser::Protocol::Protocol $0="on"
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Tuesday, July 21, 2020 10:50 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: RE: SteamDevice 2.8.x build on Windows issue
On Tue, 21 Jul 2020 at 15:01, Mark Rivers via Tech-talk <[email protected]> wrote:
Cheers,
~Ralph
Complexity comes for free, simplicity you have to work for.
SteamDevice 2.8.x build on Windows issue 吴煊 via Tech-talk
RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
RE: SteamDevice 2.8.x build on Windows issue Freddie Akeroyd - UKRI STFC via Tech-talk
Re: RE: SteamDevice 2.8.x build on Windows issue 吴煊 via Tech-talk
RE: RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
Re: RE: SteamDevice 2.8.x build on Windows issue Ralph Lange via Tech-talk
Prev: RE: RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
Next: Re: archiver viewer plug in with archiver appliance in Linux Michael Davidsaver via Tech-talk
Next: stream is installing files in the wrong place Mark Rivers via Tech-talk
