1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: pvData Introspection: Change Structure at run time
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Madden, Timothy J." <[email protected]>
Date: Mon, 27 Jul 2020 17:29:00 +0000
There are 'union' types as used for the value in the area detector data if you want to change some part of the structure at runtime, but generally I don't think you can change the structure at runtime.
The protocol exchanges the structure description at connection time, specifically at the start of a 'get' or 'monitor'. Later just the raw bits are exchanged with some reference to what part of the structure changed.
If you want to modify the structure, you'll have to basically dispose/close the channel and re-create it. Clients should then re-search and on re-connection they'll learn about the new structure.
-Kay
From: Tech-talk <[email protected]> on behalf of Madden, Timothy J. via Tech-talk <[email protected]>
Sent: Monday, July 27, 2020 1:23 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] pvData Introspection: Change Structure at run time
Folks
Most of the interfaces for Structure require a StructureConstPtr data type.
This is a pointer to an immutable structure.
Suppose I wish the structure to change at run time. What do we do?
Tim Madden
APS
pvData Introspection: Change Structure at run time Madden, Timothy J. via Tech-talk
Prev: pvData Introspection: Change Structure at run time Madden, Timothy J. via Tech-talk
Next: EDM fonts on Raspian ... Ernesto Paiser via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: pvData Introspection: Change Structure at run time Marty Kraimer via Tech-talk
