Subject: Re: pvData Introspection: Change Structure at run time
From: Marty Kraimer via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 27 Jul 2020 14:33:23 -0400
Consider using  a union field
https://github.com/epics-base/exampleCPP/blob/master/database/src/exampleDatabase.cpp
Has some examples of how to create a union .
One example is:
static void createVariantUnionArrayRecord(
    PVDatabasePtr const &master,
    string const &recordName)
    StructureConstPtr top = fieldCreate->createFieldBuilder()->
         add("timeStamp",standardField->timeStamp()) ->
         addArray("value",fieldCreate->createVariantUnion())->
         createStructure();
    PVStructurePtr pvStructure = pvDataCreate->createPVStructure(top);
    PVRecordPtr pvRecord = PVRecord::create(recordName,pvStructure);
    bool result = master->addRecord(pvRecord);
    if(!result) cout<< "record " << recordName << " not added" << endl;
field "value" can be made into any pvType you want. In your case you can make it a structure.
What "value" is can be changed at run time.
On 7/27/20 1:23 PM, Madden, Timothy J. via Tech-talk wrote:
Folks
Most of the interfaces for Structure require a StructureConstPtr data type.
This is a pointer to an immutable structure.
Suppose I wish the structure to change at run time. What do we do?
Tim Madden
APS
pvData Introspection: Change Structure at run time Madden, Timothy J. via Tech-talk
Prev: EDM fonts on Raspian ... Ernesto Paiser via Tech-talk
Next: asyn TracMask + asynMotor : function= John Dobbins via Tech-talk
Prev: Re: pvData Introspection: Change Structure at run time Kasemir, Kay via Tech-talk
Next: EDM fonts on Raspian ... Ernesto Paiser via Tech-talk
