Hi John,
If you enter ‘asynReport, 10’ on the IOC shell it will printout all the parameter names (as well as all the parameter lists), eg:
Parameter 175 type=asynInt32, name=CONTROLLER_SSICAPABLE, value=0, status=0
Cheers,
Matt
On Behalf Of John Dobbins via Tech-talk
Sent: Monday, July 27, 2020 3:15 PM
To: [email protected]
Subject: [EXTERNAL] asyn TracMask + asynMotor : function=
I am learning to use the EPICS support for the Galil motor controller. When I use
asynSetTraceMask("myAsynPort",0,8)
2020/07/27 14:59:23.327 asynMotorController:writeInt32:: axis=0, function=175, value=1
int function = pasynUser->reason;
But I don't see how to go from function=175 to the parameter defined in the source header so that this message will mean something to me.
Research Support Specialist
Cornell High Energy Synchrotron Source
Maybe it's all part of a great big ineffable plan. - Neil Gaiman, _Good Omens_
- asyn TracMask + asynMotor : function= John Dobbins via Tech-talk
Re: Old-ish CAS issue Timo Korhonen via Tech-talk
<2020>
2025
2026
Re: asyn TracMask + asynMotor : function= Torsten Bögershausen via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
