1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: cs-studio linux version that works with archiver
From: Lucas Russo via Tech-talk <[email protected]>
To: astrid morreale <[email protected]>
Date: Thu, 30 Jul 2020 11:09:51 -0300
Hi Astrid,
We, at LNLS, are using the ESS version available here, but others should work just fine: https://artifactory.esss.lu.se/artifactory/CS-Studio/production/4.6.1.25/
You can manually change the Databrowser settings (and others) by either:
1) editing the file "configuration/plugin_customization.ini" inside the CS-Studio installation directory, like this:
# Data Browser
# Removal of these settings results in empty defaults
# URLs to suggest in the "Archives" view
org.csstudio.trends.databrowser3/urls=pbraw://10.0.38.42/retrieval|LNLS Archiver
org.csstudio.trends.databrowser3/use_auto_scale=true
org.csstudio.trends.databrowser3/plot_bins=10
org.csstudio.trends.databrowser3/request_type=RAW
# Default data sources for newly added channels
# Format:  <name>|<key>|<url>
# xnds: URLs use the key. Other URLs might ignore the key.
org.csstudio.trends.databrowser3/archives=LNLS Archiver|1|pbraw://10.0.38.42/retrieval
org.csstudio.trends.databrowser3/use_default_archives=true
2) inside CS-Studio by going to "edit -> preferences -> CSS Applications -> Trends -> Data Browser"
If you are familiar with Ansible you can look at our CS-Studio role that should install everything you need
Hope this helps,
Cheers!
Lucas
On Thu, Jul 30, 2020 at 10:54 AM astrid morreale via Tech-talk <[email protected]> wrote:
Hello,
In my attempt to retrieve archived data with a viewer (other than archiver viewer) I downloaded two different  linux 4.3 versions of  cs-studio from here:
and I have  tried following using the instructions in https://slacmshankar.github.io/epicsarchiver_docs/csstudio.html .
However the last two cs-versions versions I downloaded are missing essential things like  the trend tab (and thus I cannot add my pbraw::... retrieval)
Could someone recommend a pre-compiled version of cs-studio that works with the archiver, or point me to the plugins etc that the generic cs studio is missing?
I did check that the sns-css version of cs-studio has the trend tabs but then it is heavily configured for sns operations.
kind regards and thanks in advance
Astrid
Astrid Morreale
Staff Scientist Subatomic Physics Group.
Los Alamos National Laboratory.
[email protected]
Re: cs-studio linux version that works with archiver astrid morreale via Tech-talk
Prev: cs-studio linux version that works with archiver astrid morreale via Tech-talk
Next: Re: cs-studio linux version that works with archiver astrid morreale via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
