Subject: Re: cs-studio linux version that works with archiver
From: Lucas Russo via Tech-talk <[email protected]>
To: astrid morreale <[email protected]>
Date: Thu, 30 Jul 2020 14:28:35 -0300
Hi Astrid,
Good to hear that you could make it work!
As far as I know, the "vanilla" versions of CS-Studio do not ship with many of those plugins (databrowser, alarm tree, etc). Those are added and configured by each site. So, if you need/want them you need to either use a site-specific version that includes the plugin you want or bundle it yourself.
Bundling the plugins and configuring CS-Studio to make it more specific to your site is not very difficult and some of my colleagues used to do that. You can take a look at https://github.com/ControlSystemStudio
Cheers!
Lucas
On Thu, Jul 30, 2020 at 1:59 PM astrid morreale <[email protected]> wrote:
Hi Lucas and John,
After a few trial and errors and "export" statements to make the css launch warning free,
I managed to get both versions of cs studio working and I can monitor and see my mockup/test PVs. Thank you very much!
I did try to follow Lucas instructions on the default cs-studio versions from:
  http://download.controlsystemstudio.org/release/4.3/ and it seems that these versions are missing many more features plugins that require investigating. I still could not see the trends tab despite the hints given by Lucas.
Thanks a lot again!
Il giorno gio 30 lug 2020 alle ore 08:10 Lucas Russo <[email protected]> ha scritto:
Hi Astrid,
We, at LNLS, are using the ESS version available here, but others should work just fine: https://artifactory.esss.lu.se/artifactory/CS-Studio/production/4.6.1.25/
You can manually change the Databrowser settings (and others) by either:
1) editing the file "configuration/plugin_customization.ini" inside the CS-Studio installation directory, like this:
# Data Browser
# Removal of these settings results in empty defaults
# URLs to suggest in the "Archives" view
org.csstudio.trends.databrowser3/urls=pbraw://10.0.38.42/retrieval|LNLS Archiver
org.csstudio.trends.databrowser3/use_auto_scale=true
org.csstudio.trends.databrowser3/plot_bins=10
org.csstudio.trends.databrowser3/request_type=RAW
# Default data sources for newly added channels
# Format:  <name>|<key>|<url>
# xnds: URLs use the key. Other URLs might ignore the key.
org.csstudio.trends.databrowser3/archives=LNLS Archiver|1|pbraw://10.0.38.42/retrieval
org.csstudio.trends.databrowser3/use_default_archives=true
2) inside CS-Studio by going to "edit -> preferences -> CSS Applications -> Trends -> Data Browser"
If you are familiar with Ansible you can look at our CS-Studio role that should install everything you need
Hope this helps,
Cheers!
Lucas
On Thu, Jul 30, 2020 at 10:54 AM astrid morreale via Tech-talk <[email protected]> wrote:
Hello,
In my attempt to retrieve archived data with a viewer (other than archiver viewer) I downloaded two different  linux 4.3 versions of  cs-studio from here:
and I have  tried following using the instructions in https://slacmshankar.github.io/epicsarchiver_docs/csstudio.html .
However the last two cs-versions versions I downloaded are missing essential things like  the trend tab (and thus I cannot add my pbraw::... retrieval)
Could someone recommend a pre-compiled version of cs-studio that works with the archiver, or point me to the plugins etc that the generic cs studio is missing?
I did check that the sns-css version of cs-studio has the trend tabs but then it is heavily configured for sns operations.
kind regards and thanks in advance
Astrid
Astrid Morreale
Staff Scientist Subatomic Physics Group.
Los Alamos National Laboratory.
[email protected]
Astrid Morreale
[email protected]
cs-studio linux version that works with archiver astrid morreale via Tech-talk
Re: cs-studio linux version that works with archiver Lucas Russo via Tech-talk
Re: cs-studio linux version that works with archiver astrid morreale via Tech-talk
Prev: Re: cs-studio linux version that works with archiver astrid morreale via Tech-talk
Next: RE: EPICS Base Compilation Failed Under Cygwin gcc 9+ Paul Chu via Tech-talk
Next: Attocube IDS3010 Randall Cayford via Tech-talk
