1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: looking for aai/waveform example
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 31 Jul 2020 11:33:41 +0200
For the record:
Using a recent version of EPICS Base, you can also avoid copying and swap pointers instead.
See How To Avoid Copying Arrays with waveformRecord in the EPICS How To pages.
In this specific case (shared memory involved) copying might be preferred, though.
Cheers,
~Ralph
On Thu, 30 Jul 2020 at 23:51, Hu, Yong via Tech-talk <[email protected]> wrote:
Hi Dave,
For waveform record, I usually simply use “memcpy” in the device support routine, something like this:
    memcpy(precord->bptr, pointer-to-data-source, size-of-bytes-to-be-copied);
    precord->nelm = number-of-data-point;
precord->nord = number-of-data-point;
precord is a pointer to waveformRecord.
Good luck!
Yong
looking for aai/waveform example David A. Slimmer via Tech-talk
Re: looking for aai/waveform example Hu, Yong via Tech-talk
Prev: Re: looking for aai/waveform example Hu, Yong via Tech-talk
Next: Re: Attocube IDS3010 Bradnick, Ben (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: EPICS Base Compilation Failed Under Cygwin gcc 9+ Paul Chu via Tech-talk
