Subject: Re: MiniPIX TPX3 detector
From: "Wang Xiaoqiang \(PSI\) via Tech-talk" <[email protected]>
To: "Gofron, Kazimierz" <[email protected]>
Date: Mon, 3 Aug 2020 16:06:08 +0000
This type of detector is controlled via their Pixet program,
which has an embedded Python interpreter. Then inside the program,
Python scripts can be loaded to call its API functions.
We found it mostly easy to run a PCASpy server. In case you are
interested in this approach, I can upload the script.
Best
Xiaoqiang
> On 3 Aug 2020, at 17:49, Gofron, Kazimierz via Tech-talk <[email protected]> wrote:
> Hi,
> Has anyone created EPICS support for MiniPIX TPX3 detector (with USB2 interface) in Linux?  Thanks.
> https://advacam.com/minipix
> Regards,
> Kazimierz
Re: MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Prev: MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Next: Re: EPICS Base Compilation Failed Under Cygwin gcc 9+ Johnson, Andrew N. via Tech-talk
Next: Re: MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
