Subject: Re: MiniPIX TPX3 detector
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: "Wang Xiaoqiang (PSI)" <[email protected]>
Date: Mon, 3 Aug 2020 17:33:03 +0000
Hi Xiaoqiang,
Please upload the script, since this might be the quickest way to get this compact detector running.
Kazimierz
Sent: Monday, August 3, 2020 12:06 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected] <[email protected]>
This type of detector is controlled via their Pixet program,
which has an embedded Python interpreter. Then inside the program,
Python scripts can be loaded to call its API functions.
We found it mostly easy to run a PCASpy server. In case you are
interested in this approach, I can upload the script.
Best
Xiaoqiang
> On 3 Aug 2020, at 17:49, Gofron, Kazimierz via Tech-talk <[email protected]> wrote:
> Hi,
> Has anyone created EPICS support for MiniPIX TPX3 detector (with USB2 interface) in Linux?  Thanks.
> https://urldefense.com/v3/__https://advacam.com/minipix__;!!P4SdNyxKAPE!TmgJH5XbuSkGliqnE9pGcGUxgo6g9M73xrgPxbvc0g1DpoVtGo3eylabZIEpzsCw$
> Regards,
> Kazimierz
Re: MiniPIX TPX3 detector Wang Xiaoqiang (PSI) via Tech-talk
MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Prev: Re: EPICS Base Compilation Failed Under Cygwin gcc 9+ Johnson, Andrew N. via Tech-talk
Next: Re: MiniPIX TPX3 detector Wang Xiaoqiang (PSI) via Tech-talk
Prev: Re: MiniPIX TPX3 detector Wang Xiaoqiang (PSI) via Tech-talk
