Subject: Re: HDF5 client for EPICS 3.15
From: "Jemian, Pete R. via Tech-talk" <[email protected]>
Date: Sun, 9 Aug 2020 23:07:24 +0000
Try Python.  This example needs PyEpics and h5py packages.
Here is an example:
* demo.db  example database
* demo.py  example python program
* demo.h5  example HDF5 output
Run attached demo.db with a softIoc (from EPICS base):
     softIoc -d demo.db
In separate terminal, run the demo program:
     python3 demo.py
See the output in demo.h5.  The content looks like this:
/tmp/demo/demo.h5
   wf10:float64[3] = [2.0, 4.0, 8.0]
   wf5:float64[5] = [1.0, 2.0, 3.0, 4.0, 5.0]
Pete
On 8/8/2020 3:41 PM, Ha, Kiman via Tech-talk wrote:
> Hi All,
> NSLS-II LLRF system has a new circular buffer for the LLRF system
> oscilloscope function.
> A single waveform size is 1.8 M point and a total of ~40 PVs.
> Does anyone have and any EPICS HDF client program for waveform PVs to
> HDF5 files?
> Our application is simple steps if the beam dump caused? Read waveforms
> and write HDF5 files to a specific directory (DD/MM/YYYY).
> Thanks,
> Kiman
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
       Education is the one thing for which people
          are willing to pay yet not receive.
# demo.db: read waveforms from EPICS and write HDF5 file
# softIoc -d demo.db
record(waveform, "demo:wf10") {
    field(NELM, 10)
    field(FTVL, "DOUBLE")
    field(EGU, "arbitrary")
record(waveform, "demo:wf5") {
    field(NELM, 5)
Attachment: demo.h5
Description: demo.h5
#!/usr/bin/env python
"""demo: read waveforms from EPICS and write HDF5 file"""
import epics
import h5py
wf5 = epics.PV("demo:wf5")
wf10 = epics.PV("demo:wf10")
for obj in (wf5, wf10):
    obj.wait_for_connection()
wf5.put([1,2,3,4,5])
wf10.put([2, 4, 8])
with h5py.File("demo.h5", "w") as fp:
    fp.create_dataset("wf5", data=wf5.value)
    ds = fp.create_dataset("wf10", data=wf10.value)
    ds.attrs["units"] = "arbitrary"
HDF5 client for EPICS 3.15 Ha, Kiman via Tech-talk
Prev: Re: HDF5 client for EPICS 3.15 Mark Rivers via Tech-talk
Next: Re: HDF5 client for EPICS 3.15 Mark Rivers via Tech-talk
