Subject: Re: can't find pydm widget
From: Hugo Slepicka via Tech-talk <[email protected]>
To: "Lorelli, Jeremy J" <[email protected]>
Date: Mon, 10 Aug 2020 08:18:46 -0700
Hi Geyang,
I see that you are using also Anaconda.
Please make sure that your Qt and PyQt are coming from conda-forge and not from defaults.
There is a bug with their recipe that I addressed but they did not yet pulled the patch.
If Jeremy’s solution didn’t work, please send me the output of:
conda list | grep qt
conda list | grep pydm
Cheers,
Hugo
On Mon, Aug 10, 2020 at 12:22 AM Lorelli, Jeremy J via Tech-talk <[email protected]> wrote:
Hi Geyang,
I had a similar problem when installing pydm initially. An easy fix is to create a file called designer_plugin.py with the following code in it:
from pydm.widgets.qtplugins import *
Then point PYQTDESIGNERPATH to the directory where this file is located.
Best,
Jeremy L.
From: Tech-talk <[email protected]> on behalf of Silver via Tech-talk <[email protected]>
Sent: Monday, August 10, 2020 12:06 AM
To: tech-talk <[email protected]>
Subject: can't find pydm widget
hi,
As the steps in https://slaclab.github.io/pydm/installation.html, I used Miniconda to install the software. When I run designer(QT5), I can't find pydm widget in GUI.
I try to add environment variable as: "export PYQTDESIGNERPATH=/home/iocusr/miniconda2/envs/pydm-env/lib/python3.6/site-packages/pydm/"
it didn't work. can anyone give me some suggestions? Thanks a lot.
Best wishes
Geyang 2020-08-10
can't find pydm widget Silver via Tech-talk
Re: can't find pydm widget Lorelli, Jeremy J via Tech-talk
Prev: EpicsWiki Update for EPICS 7.x Ivo Hanak via Tech-talk
Next: Re: HDF5 client for EPICS 3.15 Shen, Guobao via Tech-talk
Prev: Re: can't find pydm widget Lorelli, Jeremy J via Tech-talk
Next: EpicsWiki Update for EPICS 7.x Ivo Hanak via Tech-talk
