1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: HDF5 client for EPICS 3.15
From: "Ha, Kiman via Tech-talk" <[email protected]>
To: "Shen, Guobao" <[email protected]>, "Rivers, Mark L." <[email protected]>
Cc: "Veseli, Sinisa" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 10 Aug 2020 17:31:36 +0000
Hi Guobao,
Thank you for the excellent example of the APS machine.
I will bring up a long-term project after the technical/functions study.
Kiman
-----Original Message-----
Sent: Monday, August 10, 2020 11:47 AM
To: Ha, Kiman <[email protected]>; Rivers, Mark L. <[email protected]>
Cc: [email protected]; Arnold, Ned D. <[email protected]>; Veseli, Sinisa <[email protected]>
Subject: Re: HDF5 client for EPICS 3.15
Hi Kiman,
It seems that our DAQ system for APS-U is a good solution for your needs.
It uses EPICS7, and is based on AreaDetector.
You can either save your data into a HDF5 file using the AD HDF plugin, or stream it to your second level server for further process.
Here we plan to use it with our data management system.
Performance wise, it can handle a few 100 MB data rate with streaming mode.
Since you use it for PM purpose, the performance is not a concern.
Guobao
On 8/9/20, 10:14 PM, "Tech-talk on behalf of Ha, Kiman via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    Hi Mark,
    This application we called Post-mortem(PM) epics client and needs to run once a beam dump condition.
    As you know, the beam dump is not open it depend on machine status, but I say test mode once per ~5 miniature.
    We have a C based PM epics client application for beam operation support.
    The actual waveform size is up to 1.7 M points and a few thousand waveform PVs, for the RF, PS, BPM, AI, FOFB, BxB .
    We were trying to build a new PM epics client for the new LLRF system; that's why I am collecting information from epics experts on which concept is a more generic way for future support (maintainability, flexibility, technical support..)
    My colleague Yong Hu was working with python-based epics client applications and already got some results.
    And other experience and comments are welcome.
    Thank you for your sugession!
    Kiman
    Sent: Sunday, August 9, 2020 10:16 PM
    To give good advice on this we need to know more about the performance requirements. If we assume the waveforms are doubles (8 bytes per sample) then each capture is 1.8 M * 40 * 8 = 576 MB. How often do you need to do this, e.g. once per second, once per hour, or once per day? That could determine if a Channel Access client is practical or if you need something within the IOC.
    Sent from my iPhone
    On Aug 8, 2020, at 3:41 PM, Ha, Kiman via Tech-talk <[email protected]> wrote:
    Hi All,
    NSLS-II LLRF system has a new circular buffer for the LLRF system oscilloscope function.
    A single waveform size is 1.8 M point and a total of ~40 PVs.
    Does anyone have and any EPICS HDF client program for waveform PVs to HDF5 files?
    Our application is simple steps if the beam dump caused? Read waveforms and write HDF5 files to a specific directory (DD/MM/YYYY).
    Kiman
HDF5 client for EPICS 3.15 Ha, Kiman via Tech-talk
Re: HDF5 client for EPICS 3.15 Mark Rivers via Tech-talk
RE: HDF5 client for EPICS 3.15 Ha, Kiman via Tech-talk
Re: HDF5 client for EPICS 3.15 Shen, Guobao via Tech-talk
Prev: Re: EpicsWiki Update for EPICS 7.x Johnson, Andrew N. via Tech-talk
Next: building ioc library - multiple inclusion of Main? David A. Slimmer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: HDF5 client for EPICS 3.15 Shen, Guobao via Tech-talk
Next: can't find pydm widget Silver via Tech-talk
