1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: building ioc library - multiple inclusion of Main?
From: "David A. Slimmer via Tech-talk" <[email protected]>
Cc: "David A. Slimmer" <[email protected]>
Date: Mon, 10 Aug 2020 19:00:50 +0000
I’ve been trying to track down the reason for multiple inclusions of the xxxMain.o when I build a library.
The output of the build looks like this:
/usr/bin/ar -rc    libaaitest.a      devAaiIQM.o aaitest_registerRecordDeviceDriver.o aaitestMain.o aaitestMain.o
Where aaitestMain.o appears twice, and causes a “multiple definition of ‘main’ “ problem.
Here is my App/src/Makefile:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build an IOC support library
LIBRARY_IOC += aaitest
DBD += aaiIQM.dbd
aaitest_SRCS += devAaiIQM.cpp
aaitest_LIBS += $(EPICS_BASE_IOC_LIBS)
# additional compile flags for adinstbpm code called in device support
USR_CXXFLAGS += -g
USR_CXXFLAGS += -DNETCOMMS_TRANSPORT=UDP
USR_CXXFLAGS += -fPIC
USR_INCLUDES += -I/home/rsantucc/adinstbpm
USR_INCLUDES += -I/usr/local/products/erlang-apps/cdev-1.3/include
USR_INCLUDES += -I/usr/local/products/erlang-apps/acnet-2.2/include
USR_INCLUDES += -I/usr/local/products/include/shared/ddcp
USR_INCLUDES += -I/usr/local/products/trace/include/TRACE
USR_LDFLAGS += -lbpmclientlib
USR_LDFLAGS += -lbbpm250x12
USR_LDFLAGS += -lbtime
USR_LDFLAGS += -liotatime
USR_LDFLAGS += -lddcp
USR_LDFLAGS += -lconfig++
USR_LDFLAGS += -lnl-genl-3
USR_LDFLAGS += -lnl-3
USR_LDFLAGS += -lrt
# Build the IOC application
PROD_IOC = aaitest
# aaitest.dbd will be created and installed
DBD += aaitest.dbd
# aaitest.dbd will be made up from these files:
aaitest_DBD += base.dbd
aaitest_DBD += aaiIQM.dbd
# Include dbd files from all support applications:
#aaitest_DBD += xxx.dbd
# Add all the support libraries needed by this IOC
#aaitest_LIBS +=
# aaitest_registerRecordDeviceDriver.cpp derives from aaitest.dbd
aaitest_SRCS += aaitest_registerRecordDeviceDriver.cpp
# Build the main IOC entry point on workstation OSs.
aaitest_SRCS_DEFAULT += aaitestMain.cpp
aaitest_SRCS_vxWorks += -nil-
# Add support from base/src/vxWorks if needed
#aaitest_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
# Finally link to the EPICS Base libraries
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
Any ideas would be appreciated –
Dave
Re: building ioc library - multiple inclusion of Main? Johnson, Andrew N. via Tech-talk
Prev: RE: HDF5 client for EPICS 3.15 Ha, Kiman via Tech-talk
Next: EPICS Training for a noob? Fleming, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: EpicsWiki Update for EPICS 7.x Johnson, Andrew N. via Tech-talk
Next: Re: building ioc library - multiple inclusion of Main? Johnson, Andrew N. via Tech-talk
