Subject: Re: building ioc library - multiple inclusion of Main?
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "David A. Slimmer" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 10 Aug 2020 19:52:14 +0000
Hi David,
On Aug 10, 2020, at 2:00 PM, David A. Slimmer via Tech-talk <[email protected]> wrote:
I’ve been trying to track down the reason for multiple inclusions of the xxxMain.o when I build a library.
The output of the build looks like this:
/usr/bin/ar -rc    libaaitest.a      devAaiIQM.o aaitest_registerRecordDeviceDriver.o aaitestMain.o aaitestMain.o
Where aaitestMain.o appears twice, and causes a “multiple definition of ‘main’ “ problem.
Here is my App/src/Makefile:
So here you’re asking it to build a library called aaitest:
# Build an IOC support library
LIBRARY_IOC += aaitest
And here are the source files that should make up that library:
aaitest_SRCS += devAaiIQM.cpp
Then here you’re asking it to build a binary, also called aaitest:
# Build the IOC application
PROD_IOC = aaitest
And here are the source files to be included in that binary:
aaitest_SRCS += aaitest_registerRecordDeviceDriver.cpp
aaitest_SRCS_DEFAULT += aaitestMain.cpp
aaitest_SRCS_vxWorks += -nil-
The last 2 are just ways of telling the build system to include your Main.cpp program but only when not building for VxWorks. However they are equivalent to something like this:
ifneq ($(OS_CLASS),vxWorks)
  aaitest_SRCS += aaitestMain.cpp
endif
Any ideas would be appreciated –
You need to rename either your library or your IOC binary, since both of them use the same aaitest_SRCS variable to tell the build what source files to compile for the target object.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
building ioc library - multiple inclusion of Main? David A. Slimmer via Tech-talk
Prev: EPICS Training for a noob? Fleming, Steven via Tech-talk
Next: Re: EPICS Training for a noob? Kyle Hesse via Tech-talk
Prev: building ioc library - multiple inclusion of Main? David A. Slimmer via Tech-talk
Next: EPICS Training for a noob? Fleming, Steven via Tech-talk
