Subject: Re: ADAravis: arvFeature.cpp
From: Jure Varlec via Tech-talk <[email protected]>
To: John Dobbins <[email protected]>
Cc: [email protected]
Date: Tue, 11 Aug 2020 14:27:35 +0200
Hi John,
Aravis is changing its API and ADAravis is being updated to match. You
will need Aravis 0.7.x to get the new API.
Best
Jure
John Dobbins via Tech-talk <[email protected]> writes:
> All,
> In attempting to build ADAravis ( Aravis package 0.6.3  , base-7.0.3.1, areaDetector-master)  I encountered a number of errors along the lines
> make[5]: Entering directory `/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADAravis/aravisApp/src/O.linux-x86_64'
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/nfs/bbl/online/epics/b7/synApps/support/asyn-R4-40/include     -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADCore/include -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/compiler/gcc -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/os/Linux -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADGenICam/include     -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/local/include/aravis-0.8    -c ../arvFeature.cpp
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readInteger()\u2019:
> ../arvFeature.cpp:42:84: error: too many arguments to function \u2018gint64 arv_device_get_integer_feature_value(ArvDevice*, const char*)\u2019
>      return arv_device_get_integer_feature_value(mDevice, mFeatureName.c_str(), NULL);
> In file included from /usr/include/arvinterface.h:31:0,
>                  from /usr/include/arv.h:66,
>                  from ../arvFeature.h:8,
>                  from ../arvFeature.cpp:5:
> /usr/include/arvdevice.h:115:9: note: declared here
>  gint64  arv_device_get_integer_feature_value (ArvDevice *device, const char *feature);
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readIntegerMin()\u2019:
> ../arvFeature.cpp:47:90: error: too many arguments to function \u2018void arv_device_get_integer_feature_bounds(ArvDevice*, const char*, gint64*, gint64*)\u2019
>      arv_device_get_integer_feature_bounds(mDevice, mFeatureName.c_str(), &min, &max, NULL);
> /usr/include/arvdevice.h:116:8: note: declared here
>  void   arv_device_get_integer_feature_bounds  (ArvDevice *device, const char *feature, ....
> Any help is appreciated!
> John Dobbins
> Research Support Specialist
> Cornell High Energy Synchrotron Source
> Cornell University
> www.chess.cornell.edu<http://www.chess.cornell.edu>
> Maybe it's all part of a great big ineffable plan. - Neil Gaiman, _Good Omens_
Re: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
ADAravis: arvFeature.cpp John Dobbins via Tech-talk
Prev: ADAravis: arvFeature.cpp John Dobbins via Tech-talk
Next: Re: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
