Subject: Re: ADAravis: arvFeature.cpp
To: John Dobbins <[email protected]>, Jure Varlec <[email protected]>
Date: Tue, 11 Aug 2020 12:31:29 +0000
Hi John,
The issue is explained in the ADAravis release notes:
https://github.com/areaDetector/ADAravis/blob/master/RELEASE.md
You specifically need aravis 0.7.2.  The odd-numbered minor release numbers of aravis are unstable releases where they are changing the API.  You probably are using 0.7.3, 0.7.4, or 0.7.5 which use a different API from 0.7.2.
When 0.8.x is released the API will be stable and I will update ADAravis to that API.
From: Tech-talk <[email protected]> on behalf of Jure Varlec via Tech-talk <[email protected]>
Sent: Tuesday, August 11, 2020 7:27 AM
To: John Dobbins
Cc: [email protected]
Hi John,
Aravis is changing its API and ADAravis is being updated to match. You
will need Aravis 0.7.x to get the new API.
Best
Jure
John Dobbins via Tech-talk <[email protected]> writes:
> All,
> In attempting to build ADAravis ( Aravis package 0.6.3  , base-7.0.3.1, areaDetector-master)  I encountered a number of errors along the lines
> make[5]: Entering directory `/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADAravis/aravisApp/src/O.linux-x86_64'
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/nfs/bbl/online/epics/b7/synApps/support/asyn-R4-40/include     -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADCore/include -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/compiler/gcc -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/os/Linux -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADGenICam/include     -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/local/include/aravis-0.8    -c ../arvFeature.cpp
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readInteger()\u2019:
> ../arvFeature.cpp:42:84: error: too many arguments to function \u2018gint64 arv_device_get_integer_feature_value(ArvDevice*, const char*)\u2019
>      return arv_device_get_integer_feature_value(mDevice, mFeatureName.c_str(), NULL);
> In file included from /usr/include/arvinterface.h:31:0,
>                  from /usr/include/arv.h:66,
>                  from ../arvFeature.h:8,
>                  from ../arvFeature.cpp:5:
> /usr/include/arvdevice.h:115:9: note: declared here
>  gint64  arv_device_get_integer_feature_value (ArvDevice *device, const char *feature);
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readIntegerMin()\u2019:
> ../arvFeature.cpp:47:90: error: too many arguments to function \u2018void arv_device_get_integer_feature_bounds(ArvDevice*, const char*, gint64*, gint64*)\u2019
>      arv_device_get_integer_feature_bounds(mDevice, mFeatureName.c_str(), &min, &max, NULL);
> /usr/include/arvdevice.h:116:8: note: declared here
>  void   arv_device_get_integer_feature_bounds  (ArvDevice *device, const char *feature, ....
> Any help is appreciated!
> John Dobbins
> Research Support Specialist
> Cornell High Energy Synchrotron Source
> Cornell University
> www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu>>
> Maybe it's all part of a great big ineffable plan. - Neil Gaiman, _Good Omens_
Re: ADAravis: arvFeature.cpp John Dobbins via Tech-talk
Re: ADAravis: arvFeature.cpp Jure Varlec via Tech-talk
Prev: Re: ADAravis: arvFeature.cpp Jure Varlec via Tech-talk
Next: Phoebus X-Y Graph Florian Feldbauer via Tech-talk
Next: Re: ADAravis: arvFeature.cpp John Dobbins via Tech-talk
