Subject: Re: ADAravis: arvFeature.cpp
From: John Dobbins via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Jure Varlec <[email protected]>
Date: Wed, 12 Aug 2020 17:37:21 +0000
Mark,
Do you recall which of these Meson options are actually needed by ADAravis?:
usb
viewer
gst-plugin
John
Sent: Tuesday, August 11, 2020 8:31 AM
To: John Dobbins <[email protected]>; Jure Varlec <[email protected]>
Cc: [email protected] <[email protected]>
Hi John,
The issue is explained in the ADAravis release notes:
https://github.com/areaDetector/ADAravis/blob/master/RELEASE.md
You specifically need aravis 0.7.2.  The odd-numbered minor release numbers of aravis are unstable releases where they are changing the API.  You probably are using 0.7.3, 0.7.4, or 0.7.5 which use a different API from 0.7.2.
When 0.8.x is released the API will be stable and I will update ADAravis to that API.
From: Tech-talk <[email protected]> on behalf of Jure Varlec via Tech-talk <[email protected]>
Sent: Tuesday, August 11, 2020 7:27 AM
To: John Dobbins
Hi John,
Aravis is changing its API and ADAravis is being updated to match. You
will need Aravis 0.7.x to get the new API.
Best
Jure
John Dobbins via Tech-talk <[email protected]> writes:
> All,
> In attempting to build ADAravis ( Aravis package 0.6.3  , base-7.0.3.1, areaDetector-master)  I encountered a number of errors along the lines
> make[5]: Entering directory `/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADAravis/aravisApp/src/O.linux-x86_64'
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/nfs/bbl/online/epics/b7/synApps/support/asyn-R4-40/include     -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADCore/include -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/compiler/gcc -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/os/Linux -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADGenICam/include     -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/local/include/aravis-0.8    -c ../arvFeature.cpp
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readInteger()\u2019:
> ../arvFeature.cpp:42:84: error: too many arguments to function \u2018gint64 arv_device_get_integer_feature_value(ArvDevice*, const char*)\u2019
>      return arv_device_get_integer_feature_value(mDevice, mFeatureName.c_str(), NULL);
> In file included from /usr/include/arvinterface.h:31:0,
>                  from /usr/include/arv.h:66,
>                  from ../arvFeature.h:8,
>                  from ../arvFeature.cpp:5:
> /usr/include/arvdevice.h:115:9: note: declared here
>  gint64  arv_device_get_integer_feature_value (ArvDevice *device, const char *feature);
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readIntegerMin()\u2019:
> ../arvFeature.cpp:47:90: error: too many arguments to function \u2018void arv_device_get_integer_feature_bounds(ArvDevice*, const char*, gint64*, gint64*)\u2019
>      arv_device_get_integer_feature_bounds(mDevice, mFeatureName.c_str(), &min, &max, NULL);
> /usr/include/arvdevice.h:116:8: note: declared here
>  void   arv_device_get_integer_feature_bounds  (ArvDevice *device, const char *feature, ....
> Any help is appreciated!
> John Dobbins
> Research Support Specialist
> Cornell High Energy Synchrotron Source
> Cornell University
> www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu<http://www.chess.cornell.edu>>
> Maybe it's all part of a great big ineffable plan. - Neil Gaiman, _Good Omens_
RE: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
ADAravis: arvFeature.cpp John Dobbins via Tech-talk
Re: ADAravis: arvFeature.cpp Jure Varlec via Tech-talk
Re: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
Prev: New Focus 8753 John Dobbins via Tech-talk
Next: RE: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
Prev: Re: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
