Subject: RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
To: "'Gofron, Kazimierz'" <[email protected]>
Date: Thu, 13 Aug 2020 21:49:17 +0000
The first thing to test is to see if it is a problem with the Java PVA client used in ImageJ.  Does pvget work to read the NTNDArray on the same computer that is running ImageJ?
Sent: Thursday, August 13, 2020 4:41 PM
Cc: [email protected]
Subject: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
Hi Mark,
The 10.10.2.4, and 10.10.1.3 are ioc server interfaces where camera ioc is running.
kgofron@xf10idd-ioc1:~$ /sbin/ifconfig
eth2      Link encap:Ethernet  HWaddr 40:f2:e9:f1:5e:5c
          inet addr:10.10.2.4  Bcast:10.10.3.255  Mask:255.255.254.0
eth5      Link encap:Ethernet  HWaddr 40:f2:e9:18:04:d4
          inet addr:10.10.0.2  Bcast:10.10.0.255  Mask:255.255.255.0
          inet6 addr: fe80::42f2:e9ff:fe18:4d4/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:9000  Metric:1
          RX packets:13366912123 errors:0 dropped:15 overruns:2093 frame:0
          TX packets:58127067732 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:1107045874580 (1.0 TiB)  TX bytes:138303991851304 (125.7 TiB)
eth6      Link encap:Ethernet  HWaddr 40:f2:e9:18:04:d0
          inet addr:10.10.1.3  Bcast:10.10.1.255  Mask:255.255.255.0
          inet6 addr: fe80::42f2:e9ff:fe18:4d0/64 Scope:Link
          RX packets:10991622206 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3222525720 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:76509026723747 (69.5 TiB)  TX bytes:24100596376483 (21.9 TiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
I have never seen these errors either with old-old version of PvA plugin that runs on other workstations.
K
Sent: Thursday, August 13, 2020 5:33 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected] <[email protected]>
Hi Kaz,
Ø  Camera Manta G-125B
Ø  S/N: xxxxx
Ø  Firmware: 00.01.44.18241
Ø  SDK: 1.26
Ø  Driver: 2.5.0
Ø  ADCore: 3.5.0
None of that should matter.
Ø  kgofron@xf10id-ws1:~$ export EPICS_CA_MAX_ARRAY_BYTES=6000000
That is not relevant to pvAccess.
Ø  Aug 13, 2020 4:59:34 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
Ø  SEVERE: Failed to create transport for: /10.10.0.2:48464
Ø  org.epics.pvaccess.impl.remote.ConnectionException: Failed to connect to '/10.10.0.2:48464'.
Ø  SEVERE: Failed to create transport for: /10.10.1.3:48464
Ø  org.epics.pvaccess.impl.remote.ConnectionException: Failed to connect to '/10.10.1.3:48464'.
I have never seen errors like those, so I don’t know what could be wrong.
Ø  My EPICS VLAN interfaces are on 10.10.0.x, and interfaces 10.10.1.y are for direct access to webcams.
What is at IP addresses 10.10.0.2 and 10.10.1.3?
From: Tech-talk <[email protected]> On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: Thursday, August 13, 2020 4:17 PM
To: [email protected]
Subject: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
Camera Manta G-125B
S/N: xxxxx
SDK: 1.26
Driver: 2.5.0
ADCore: 3.5.0
OS (client where imagej is running): Debian 10
OS (EPICS ioc server): Debian 7
imagej debian version:
kgofron@xf10id-ws1:~$ dpkg -l | grep imagej
ii  imagej                                        1.52j-1                                      all          Image processing program with a focus on microscopy images
I just cloned the master version of imagej viewers, and 'EPICS_AD Viewer' CA version works fine, but the 'EPICS_NTNDA_VIEWER' PVA version does not connect. Am I missing something?
In the same time CSS opi displays PvA images correctly.
kgofron@xf10id-ws1:~$ imagej
Open other images in this ImageJ panel as follows:
  imagej -p 1 <image1> [<image2> ... <imageN>]
at org.epics.pvaccess.client.impl.remote.tcp.BlockingTCPConnector.connect(BlockingTCPConnector.java:163)
at org.epics.pvaccess.client.impl.remote.ClientContextImpl.getTransport(ClientContextImpl.java:1125)
at org.epics.pvaccess.client.impl.remote.ChannelImpl.searchResponse(ChannelImpl.java:453)
at org.epics.pvaccess.client.impl.remote.search.SimpleChannelSearchManagerImpl.searchResponse(SimpleChannelSearchManagerImpl.java:384)
at org.epics.pvaccess.client.impl.remote.handlers.SearchResponseHandler.handleResponse(SearchResponseHandler.java:94)
at org.epics.pvaccess.client.impl.remote.ClientResponseHandler.handleResponse(ClientResponseHandler.java:108)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport.processBuffer(BlockingUDPTransport.java:336)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport.processRead(BlockingUDPTransport.java:263)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport$1.run(BlockingUDPTransport.java:159)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.NoClassDefFoundError: org/omg/CORBA/ShortHolder
at org.epics.pvaccess.impl.remote.IntrospectionRegistry.<init>(IntrospectionRegistry.java:77)
at org.epics.pvaccess.impl.remote.tcp.BlockingTCPTransport.<init>(BlockingTCPTransport.java:64)
at org.epics.pvaccess.client.impl.remote.tcp.BlockingClientTCPTransport.<init>(BlockingClientTCPTransport.java:96)
at org.epics.pvaccess.client.impl.remote.ClientContextImpl$1.create(ClientContextImpl.java:417)
at org.epics.pvaccess.client.impl.remote.tcp.BlockingTCPConnector.connect(BlockingTCPConnector.java:137)
... 9 more
Caused by: java.lang.ClassNotFoundException: org.omg.CORBA.ShortHolder
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:471)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:589)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 14 more
... 9 more
Aug 13, 2020 4:59:35 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
... 9 more
... 9 more
Aug 13, 2020 4:59:36 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:38 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:39 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:42 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:49 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:50 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
Aug 13, 2020 4:59:51 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
Prev: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
Next: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers J. Lewis Muir via Tech-talk
Next: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
