Subject: Re: Calling external program and read return value into record
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Christian Pauly <[email protected]>
Date: Fri, 14 Aug 2020 14:11:51 +0000
Record links will do string to number conversions for you automatically. As long as you don’t need to remove leading characters from the string you can just point an ai.INP field at the string and it will convert it to a double automatically.
- Andrew
Complicity is easy, Simplexity takes real work
> On Aug 14, 2020, at 3:17 AM, Christian Pauly via Tech-talk <[email protected]> wrote:
> Hej Folks
> Again i am facing the problem to call an external program (to read out a sensor), but this time i would like to get the stdout output from this program (the sensor value) into a record.
> I am trying to use the ExecuteDevice module for this, and basically it works. Here is what i do:
> record(bo,      "$(P)$(R)AirFlowRun")
>  field(SCAN,   "1 second")
>  field(DTYP,   "execute")
>  field(OUT,    "@ReadFlow run")
>  field(FLNK,   "$(P)$(R)AirFlowStr")
> record(stringin, "$(P)$(R)AirFlowStr")
>  field(DESC,   "Measured Air Flow as String")
>  field(INP,    "@ReadFlow stdout")
>  field(FLNK,   "$(P)$(R)AirFlow")
> record(scalcout, "$(P)$(R)AirFlow")
>  field(INAA,   "$(P)$(R)AirFlowStr.VAL")
>  field(CALC,   "AA")
> The first record executes the external program, and once done it forwards to the second record to readout the stdout output. So far it works.
> Problem: The second record has to be a stringin record, so i have the output only as string not as number. record type ai is not supported by the EcecuteDevice module.
> In order to convert the string into a usable number i am trying to use the third "scalcout" record. It should retrieve the string via input link, and simply convert it to a float number.
> However: Specifying the input link "INAA" does not work, i get an error
> "2020/08/14 10:03:51.229277 _main_ CBM:Lauda:AirFlow: Wrong I/O link type CONSTANT"
> Acording to the scalcout documentation, it should be possible to use a link as input, so i dont get why this is not working...
> Or is there an even simpler way to achieve the goal ?
> As always: Any help or suggestionis very welcome !!
> Best regards,
> Christian
Calling external program and read return value into record Christian Pauly via Tech-talk
Prev: Re: Calling external program and read return value into record Mark Rivers via Tech-talk
Next: Re: Calling external program and read return value into record Mooney, Tim M. via Tech-talk
Prev: Re: Calling external program and read return value into record Mooney, Tim M. via Tech-talk
Next: Question about static linking in the EPICS build system Wlodek, Jakub via Tech-talk
