Subject: Calling external program and read return value into record
From: Christian Pauly via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 14 Aug 2020 10:16:45 +0200
Hej Folks
Again i am facing the problem to call an external program (to read out a sensor), but this time i would like to get the stdout output from this program (the sensor value) into a record.
I am trying to use the ExecuteDevice module for this, and basically it works. Here is what i do:
record(bo,      "$(P)$(R)AirFlowRun")
  field(SCAN,   "1 second")
  field(DTYP,   "execute")
  field(OUT,    "@ReadFlow run")
  field(FLNK,   "$(P)$(R)AirFlowStr")
record(stringin, "$(P)$(R)AirFlowStr")
  field(DESC,   "Measured Air Flow as String")
  field(INP,    "@ReadFlow stdout")
  field(FLNK,   "$(P)$(R)AirFlow")
record(scalcout, "$(P)$(R)AirFlow")
  field(INAA,   "$(P)$(R)AirFlowStr.VAL")
  field(CALC,   "AA")
The first record executes the external program, and once done it forwards to the second record to readout the stdout output. So far it works. Problem: The second record has to be a stringin record, so i have the output only as string not as number. record type ai is not supported by the EcecuteDevice module.
In order to convert the string into a usable number i am trying to use the third "scalcout" record. It should retrieve the string via input link, and simply convert it to a float number.
However: Specifying the input link "INAA" does not work, i get an error
"2020/08/14 10:03:51.229277 _main_ CBM:Lauda:AirFlow: Wrong I/O link type CONSTANT"
Acording to the scalcout documentation, it should be possible to use a link as input, so i dont get why this is not working...
Or is there an even simpler way to achieve the goal ?
As always: Any help or suggestionis very welcome !!
Best regards,
Christian
Re: Calling external program and read return value into record Mark Rivers via Tech-talk
Re: Calling external program and read return value into record Johnson, Andrew N. via Tech-talk
Prev: Questions concerning Phoebus Florian Feldbauer via Tech-talk
Next: Re: Calling external program and read return value into record Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] Questions concerning Phoebus Kasemir, Kay via Tech-talk
