1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: cannot read epics archive(d) data with CS-studio
From: Michael Davidsaver via Tech-talk <[email protected]>
To: astrid morreale <[email protected]>
Date: Sat, 15 Aug 2020 07:42:03 -0700
On 8/14/20 9:36 PM, astrid morreale wrote:
> Hi Michael, yes thanks a lot for the  hints.
> So I can see the archiver page and I can check that the PV's exist and are being archived.
> I also checked the log messages in Cs studio and it tells me that no data is archived. ...
> ie for the PV  BOS it tells me:
> No data found for PV optimized_800(BOS) + using URL http://myspecialurl:17668/retrieval/data/getData.raw?pv=optimized_800%28BOS%29&from=2020-08-13T11%3A38%3A38.727-05%3A00&to=2020-08-14T11%3A38%3A38.727-05%3A00
> so either the retrieval url is somewhere wrong. (it is the same one from the appliances.xml )
> or somewhere a server port is not open?? (I am guessing here)
Any easy way to see if this is a connectivity issue is to put
the URL above into a web browser, or query from the command
line with 'curl'.
I suspect it will work.  "No data found" doesn't seem like
a TCP connection problem, a timeout, or an HTTP error code.
So I would suggest looking more closely at the archiver detailed
status page for the PV in question.  In particular this page
should show the timestamp for the most recent data update stored.
Also some counters of update received, and updates dropped for
various reasons.
> Thanks.
> Il giorno ven 14 ago 2020 alle ore 19:20 Michael Davidsaver <[email protected] <mailto:[email protected]>> ha scritto:
>     On 8/13/20 4:21 PM, astrid morreale via Tech-talk wrote:
>     > Hello everyone,
>     > I have successfully installed tested my epics->Archiver appl-> cs studio locally
>     > and I have no problems seeing both archived data as well as lived data on my local computer.
>     > I have tried to reproduce the last step at some remote machine at FNAL for my experiment and I can only see live data.
>     > Some notes for the remote version:
>     > 1.I did not install the archiver nor epics myself.
>     Have you tried the URL you were given in a web browser on
>     the same computer?
>     Are you able to see the archiver status page?  cs-studio may need to
>     be told about any http proxy in between your client machine and the
>     archiver machine.
>     If so, can you check the status of the PVs you're trying to retrieve?
>     > As I can see the live data it means my pbraw/ data_retrieval_url  structure from the appliances.xml file and feed to the trends should be fine (?)
>     Live data comes directly from IOCs (eg. via Channel Access protocol),
>     and not through any archiver.
>     > 2. The storage directory remotely is different from what I tested locally.
>     > I installed mine under /home/arch whereas remotely is somewhere else.
>     > This said I checked the remote storage directory and there is lots of data archived.
>     > Could it be that the storage location may be faulting the cs-studio communication with the archiver?
>     The storage directories are an internal configuration for the
>     archiver.  Clients never access there directories directly.
>     All data is retrieved through the archiver server (eg. via HTTP).
>     > any help hints will be appreciated, Thanks in advance.
>     When you run cs-studio, do you see any error messages printed
>     which related to the archiver?  You might have to search
>     for mentions of the archiver URL.
> Astrid Morreale
> Staff Scientist Subatomic Physics Group.
> Los Alamos National Laboratory.
Re: cannot read epics archive(d) data with CS-studio astrid morreale via Tech-talk
Re: cannot read epics archive(d) data with CS-studio Michael Davidsaver via Tech-talk
Prev: Re: cannot read epics archive(d) data with CS-studio astrid morreale via Tech-talk
Next: Re: cannot read epics archive(d) data with CS-studio astrid morreale via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
