Hi Michael, "Any easy way to see if this is a connectivity issue is to put the URL above into a web browser, or query from the command line with 'curl'. I suspect it will work. "No data found" doesn't seem like a TCP connection problem, a timeout, or an HTTP error code." I followed your suggestion but it does not work Exception report message Servlet execution threw an exception description The server encountered an internal error that prevented it from fulfilling this request. exception javax.servlet.ServletException: Servlet execution threw an exception org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) root cause java.lang.NoClassDefFoundError: Could not initialize class org.epics.archiverappliance.utils.nio.ArchPaths org.epics.archiverappliance.common.BasicContext.<init>(BasicContext.java:25) org.epics.archiverappliance.retrieval.DataRetrievalServlet.doGetSinglePV(DataRetrievalServlet.java:436) org.epics.archiverappliance.retrieval.DataRetrievalServlet.doGet(DataRetrievalServlet.java:142) javax.servlet.http.HttpServlet.service(HttpServlet.java:624) javax.servlet.http.HttpServlet.service(HttpServlet.java:731) org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52 I did some digging on the archiver installation and I found a few errors that may give me a hint,At least I am convinced now that this is an archiver problem and not Cs-studio SEVERE:
Servlet.service() for servlet [DataRetrievalServlet] in context with
path [/retrieval] threw exception [Servlet execution threw an exception]
with root cause java.lang.NoClassDefFoundError: Could not initialize class org.epics.archiverappliance.utils.nio.ArchPathsalso I found an inconsistency with the retrieval url definition in the appliance.xmlthe localhost above should be replaced with "myspecialurl" I am not sure what the local computer would be since all should be storedin myspecialurl. Any thoughts? and thanks for all your advice. Astrid Il giorno sab 15 ago 2020 alle ore 08:42 Michael Davidsaver <[email protected]> ha scritto: On 8/14/20 9:36 PM, astrid morreale wrote: -- Astrid Morreale
Staff Scientist Subatomic Physics Group. Los Alamos National Laboratory. [email protected]
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
