1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: EPICS7 and Python
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: "Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk" <[email protected]>, Juan F. Esteban Müller <[email protected]>
Date: Tue, 18 Aug 2020 14:56:06 +0000
Hi Juan,
Did you install p4p using pip, or as an EPICS module from source?
If you installed via pip, what version of epicscorelibs did it pull in?
Personally, I always install it with pip, and it pulls in a version of epicscorelibs with a matching version of epics base bundled in it. I'm not sure what happens if you try to then load a different version of epics base into the same Python process, I imagine you might get odd issues like you have seen.
My suggestion would be to make pyepics use the bundled version of epics base as suggested here:
Tom
From: Tech-talk <[email protected]> on behalf of Juan F. Esteban Müller via Tech-talk <[email protected]>
Sent: 18 August 2020 13:39
To: Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]>
Hi again,
It seems that if I create a CA context before importing the p4p client, it all works fine. It is still a mystery for me, but it seems to be a good workaround for the moment.
import epics
epics.ca.create_context()
import p4p.client.thread
Cheers,
Juan
From: Tech-talk <[email protected]> on behalf of "Juan F. Esteban Müller via Tech-talk" <[email protected]>
Reply-To: "Juan F. Esteban Müller" <[email protected]>
Date: Tuesday, 18 August 2020 at 11:18
Subject: EPICS7 and Python
Hi all,
I have been using CA and PVA clients in Python for some time, but in the last few days I started to have issues. I recently updated to macos Catalina and python 3.7.7, and I am using epics base 7.0.4.
I wrote a small script to reproduce my issues:
import time
from __future__ import print_function
import epics
pv = epics.PV('SOME:PV', connection_callback=lambda pvname,conn,pv: print('connected'))
time.sleep(1)
pv.connect(timeout=0)
pv.get()
This script fails to connect to the PV if I run it on python 3.7.7, using pyepics 3.4.2 with PYEPICS_LIBCA pointing to epics base 7.0.4, and p4p 3.5.1. Even trying to stop the python interpreter with ctrl-C doesn’t work, I have to kill the process. Removing the p4p import fixes the issue.
I tried different EPICS7 releases and all fail, while EPICSv3 seems to work just fine. Unsetting PYEPICS_LIBCA also works, because the internal ca lib is 3.16.
It also runs fine on python 2.7, with and without PYEPICS_LIBCA pointing to epics base 7.
Any clue where the issue might be? Thanks!
Best regards,
Juan
EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Prev: Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Next: Re: EPICS7 and Python Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
