1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: EPICS7 and Python
From: Juan F. Esteban Müller via Tech-talk <[email protected]>
To: "Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk" <[email protected]>
Date: Tue, 18 Aug 2020 09:18:34 +0000
Hi all,
I have been using CA and PVA clients in Python for some time, but in the last few days I started to have issues. I recently updated to macos Catalina and python 3.7.7, and I am using epics base 7.0.4.
I wrote a small script to reproduce my issues:
import time
from __future__ import print_function
import epics
import p4p.client.thread
pv = epics.PV('SOME:PV', connection_callback=lambda pvname,conn,pv: print('connected'))
time.sleep(1)
pv.connect(timeout=0)
pv.get()
This script fails to connect to the PV if I run it on python 3.7.7, using pyepics 3.4.2 with PYEPICS_LIBCA pointing to epics base 7.0.4, and p4p 3.5.1. Even trying to stop the python interpreter with ctrl-C doesn’t work, I have to kill the process. Removing the p4p import fixes the issue.
I tried different EPICS7 releases and all fail, while EPICSv3 seems to work just fine. Unsetting PYEPICS_LIBCA also works, because the internal ca lib is 3.16.
It also runs fine on python 2.7, with and without PYEPICS_LIBCA pointing to epics base 7.
Any clue where the issue might be? Thanks!
Best regards,
Juan
Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Re: EPICS7 and Python Matt Newville via Tech-talk
Prev: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: How to write a soft record with a constant long string value Johnson, Andrew N. via Tech-talk
