Subject: Re: How to write a soft record with a constant long string value
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Cobb, Tom (DLSLtd,RAL,LSCI)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 19 Aug 2020 18:03:19 +0000
Hi Tom,
On Aug 19, 2020, at 7:18 AM, Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]> wrote:
Thanks for the suggestion, I made waveform device support:
It seems to work, apart from one issue: escaped quotes appear in the info as unescaped quotes:
$ cat info.db
record(waveform, TEST) {
  info(json, {"this": "has \"quotes\" in"})
$ softIoc -d info.db
epics> dbli TEST info(json, "{"this":"has "quotes" in"}")
When I use dbGetInfo to get the string, it appears the same as dbli shows.
Is this a bug, or is there a different way of escaping quotes?
Ahh yes, we have a known issue with the parser escaping JSON when it shouldn’t that will be fixed when my JSON-5 PR gets merged, hopefully in the next release. I can send you a short patch for Base, or you should be able to do either of these instead (your JSON parser should understand \u0022 as a double-quote:
woz$ cat ~/db/test.db
record(lsi, "json") {
  info(json, {"this": "has \\\"quotes\\u0022 in"})
woz$ bin/darwin-x86/softIoc -d ~/db/test.db
epics> dbli
json info(json, "{"this":"has \"quotes\u0022 in"}")
- Andrew
Sent: 18 August 2020 16:45
To: Cobb, Tom (DLSLtd,RAL,LSCI) <[email protected]>
Hi Tom,
On Aug 18, 2020, at 4:04 AM, Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]> wrote:
I would like to write a database file with a single record that holds a constant chunk of JSON (generated by a script at IOC build time). I would prefer to do this by writing the JSON into the database file itself, rather than having to use a separate file, or dbpf.
Does anyone know if this is possible?
You can load arbitrary JSON into a record info tag, but not directly into any other field type at the moment. It should be relatively easy to write device support or an aSub subroutine to copy the contents of an info tag into a long string field though:
  info(json, {"this": ["is", "json"], # Comments,
    # spaces and newlines are stripped.
    "does": ["this", "help?"]})
dbLoadDatabase("/Users/anj/Software/epics/base-7.0/bin/darwin-x86/../../dbd/softIoc.dbd")
softIoc_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("/Users/anj/db/test.db")
iocInit()
Starting iocInit
## EPICS R7.0.4.1-rc1-DEV
## Rev. R7.0.4.1-rc1-14-ga808e3c7900b79f22eb5-dirty
epics> dbli
json info(json, "{"this":["is","json"],"does":["this","help?"]}")
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: How to write a soft record with a constant long string value Johnson, Andrew N. via Tech-talk
Re: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
Next: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
Prev: Re: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
