Subject: Re: How to write a soft record with a constant long string value
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Cobb, Tom (DLSLtd,RAL,LSCI)" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 18 Aug 2020 15:45:10 +0000
Hi Tom,
On Aug 18, 2020, at 4:04 AM, Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]> wrote:
I would like to write a database file with a single record that holds a constant chunk of JSON (generated by a script at IOC build time). I would prefer to do this by writing the JSON into the database file itself, rather than having to use a separate file, or dbpf.
Does anyone know if this is possible?
You can load arbitrary JSON into a record info tag, but not directly into any other field type at the moment. It should be relatively easy to write device support or an aSub subroutine to copy the contents of an info tag into a long string field though:
woz$ cat ~/db/test.db
record(lsi, "json") {
  info(json, {"this": ["is", "json"], # Comments,
    # spaces and newlines are stripped.
    "does": ["this", "help?"]})
woz$ bin/darwin-x86/softIoc -d ~/db/test.db
dbLoadDatabase("/Users/anj/Software/epics/base-7.0/bin/darwin-x86/../../dbd/softIoc.dbd")
softIoc_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("/Users/anj/db/test.db")
iocInit()
Starting iocInit
## EPICS R7.0.4.1-rc1-DEV
## Rev. R7.0.4.1-rc1-14-ga808e3c7900b79f22eb5-dirty
epics> dbli
json info(json, "{"this":["is","json"],"does":["this","help?"]}")
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Re: EPICS7 and Python Matt Newville via Tech-talk
Next: Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Prev: Re: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
