Subject: Re: EPICS7 and Python
From: Matt Newville via Tech-talk <[email protected]>
To: Juan F. Esteban Müller <[email protected]>
Cc: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
Date: Tue, 18 Aug 2020 10:43:35 -0500
Hi Juan,
On Tue, Aug 18, 2020 at 4:18 AM Juan F. Esteban Müller via Tech-talk <[email protected]> wrote:
Hi all,
I have been using CA and PVA clients in Python for some time, but in the last few days I started to have issues. I recently updated to macos Catalina and python 3.7.7, and I am using epics base 7.0.4.
I wrote a small script to reproduce my issues:
import time
from __future__ import print_function
import epics
import p4p.client.thread
pv = epics.PV('SOME:PV', connection_callback=lambda pvname,conn,pv: print('connected'))
time.sleep(1)
pv.connect(timeout=0)
pv.get()
This script fails to connect to the PV if I run it on python 3.7.7, using pyepics 3.4.2 with PYEPICS_LIBCA pointing to epics base 7.0.4, and p4p 3.5.1. Even trying to stop the python interpreter with ctrl-C doesn’t work, I have to kill the process. Removing the p4p import fixes the issue.
I tried different EPICS7 releases and all fail, while EPICSv3 seems to work just fine. Unsetting PYEPICS_LIBCA also works, because the internal ca lib is 3.16.
It also runs fine on python 2.7, with and without PYEPICS_LIBCA pointing to epics base 7.
Any clue where the issue might be? Thanks!
Best regards,
Juan
Hm, I'm not sure.  That (or something very close to it) actually works for me on MacOS Cataline (10.15.5), using either the built-in libca (as you see) or the one distributed with 'epicscorelibs'.  I'm using Anaconda Python 3.7.7, pyepics 3.4.2, and did a fresh install of p4p with `pip install p4p`, which installed epicscorelibs 7.0.3.99.
I guess the only difference from your setup is the version of epicscore/base being 7.0.3.99 instead of 7.0.4.  Maybe that goes to Tom's and Michael's questions about how you installed 7.0.4?
Python 3.7.7 (default, Mar 23 2020, 17:31:31)
[Clang 4.0.1 (tags/RELEASE_401/final)] :: Anaconda, Inc. on darwin
Type "help", "copyright", "credits" or "license" for more information.
Imported history from '/Users/Newville/.pyhist'
>>> import os
>>> os.environ['PYEPICS_LIBCA'] = '/Users/Newville/opt/anaconda3/lib/python3.7/site-packages/epicscorelibs/lib/libca.7.0.3.99.4.dylib'
>>> import epics
>>> import p4p
>>> epics.caget('13IDA:m1.VAL')
-0.25
>>> epics.ca.libca
<CDLL '/Users/Newville/opt/anaconda3/lib/python3.7/site-packages/epicscorelibs/lib/libca.7.0.3.99.4.dylib', handle 7fe3ceeada70 at 0x7fe3ceb7c6d0>
>>> pv = epics.PV('13IDA:m2.VAL', connection_callback=lambda pvname,conn,pv: print('connected'))
connected
>>> pv.get()
0.8
--Matt
Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Prev: Re: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: How to write a soft record with a constant long string value Johnson, Andrew N. via Tech-talk
Prev: Re: EPICS7 and Python Michael Davidsaver via Tech-talk
Next: Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
