1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: How to write a soft record with a constant long string value
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Cobb, Tom (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Tue, 18 Aug 2020 15:40:28 +0000
This is my best attempt so far:
record(waveform, "TEST") {
  field(NELM, 200)
  field(FTVL, "STRING")
  field(INP, [
    "a line that contains up to 39 chars,",
    "a space will be inserted before the",
    "next line. 'This works too', and so",
    "does {}, but backslash n and",
    "backslash escaped double quotes",
    "don't *seem* to work."
$ caget TEST.VAL
TEST.VAL 200 a line that contains up to 39 chars, a space will be inserted before the next line. \'This works too\', and so does {}, but backslash n and backslash escaped double quotes don\'t *seem* to work.
The lack of \" makes it a bit difficult to put JSON in it, although I could always use a single quote and convert on the client...
I've tried the const JSON links too, but they also don't accept escaped quotes.
Any other ideas?
Tom
From: Tech-talk <[email protected]> on behalf of Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]>
Sent: 18 August 2020 10:04
To: [email protected] <[email protected]>
Subject: How to write a soft record with a constant long string value
Hi all,
I would like to write a database file with a single record that holds a constant chunk of JSON (generated by a script at IOC build time). I would prefer to do this by writing the JSON into the database file itself, rather than having to use a separate file, or dbpf.
Does anyone know if this is possible?
Tom
How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: redundancy materials saleem khan via Tech-talk
Next: Re: EPICS7 and Python Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: How to write a soft record with a constant long string value Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: How to write a soft record with a constant long string value Johnson, Andrew N. via Tech-talk
