Hi Andrew,
Thanks for the suggestion, I made waveform device support:
It seems to work, apart from one issue: escaped quotes appear in the info as unescaped quotes:
$ cat info.db
record(waveform, TEST) {
info(json, {"this": "has \"quotes\" in"})
}$ softIoc -d info.db ... epics> dbli
TEST info(json, "{"this":"has "quotes" in"}")
When I use dbGetInfo to get the string, it appears the same as dbli shows.
Is this a bug, or is there a different way of escaping quotes?
Tom
Hi Tom,
On Aug 18, 2020, at 4:04 AM, Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk < [email protected]> wrote:
I would like to write a database file with a single record that holds a constant chunk of JSON (generated by a script at IOC build time). I would prefer to do this by writing the JSON into the database file itself, rather
than having to use a separate file, or dbpf.
Does anyone know if this is possible?
You can load arbitrary JSON into a record info tag, but not directly into any other field type at the moment. It should be relatively easy to write device support or an aSub subroutine to copy the contents of an info tag into a long string field
though:
woz$ cat ~/db/test.db
record(lsi, "json") {
info(json, {"this": ["is", "json"], # Comments,
# spaces and newlines are stripped.
"does": ["this", "help?"]})
woz$ bin/darwin-x86/softIoc -d
~/db/test.db
dbLoadDatabase("/Users/anj/Software/epics/base-7.0/bin/darwin-x86/../../dbd/softIoc.dbd")
softIoc_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("/Users/anj/db/test.db")
iocInit()
Starting iocInit
## EPICS R7.0.4.1-rc1-DEV
## Rev. R7.0.4.1-rc1-14-ga808e3c7900b79f22eb5-dirty
epics> dbli
json info(json, "{"this":["is","json"],"does":["this","help?"]}")
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd. Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments are free from viruses and we cannot accept liability for any damage which you may sustain as a result of software viruses which may be transmitted in or with the message. Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
