Subject: data format conversion
To: tech-talk <[email protected]>
Date: Fri, 21 Aug 2020 09:43:49 +0800
Hello everyone,
I am using the stream device to gat data from a device, and have a problem about format conbersion.  I  hope to get some advice and will appreciate for your help.
I want to send data, such as "09", in hexademical format to the device.  the device will return  a float data %f.
Statements in the db file:
  recorrd(ai, "$(P)$(R)read")
        field(DESC, "read pressure")
        field(DTYP, "stream")
        field(INP, "@pressure.proto SendCommand(09)  $(PORT)")
        field(SCAN, "1 second")
Statements in the protocol file is like this:
SendCommand{
    out "\x\$1";
    in "%f";
when I run the st.cmd, an error occurs:
Hex digit expected after \x:  "\X""
if "09" is send directly, not as a variable "\$1":
SendCommand{
    out "\x09";
    in "%f";
everything goes well and I can get the returned %f correctly.
I wonder how can I send "09" as a variable?  How to change a variable in the record to be hexadecimal?
Thank you very much for any advice, I will try it and give feedback.
Bset wishes
Chunxia Yin
Re: data format conversion Florian Feldbauer via Tech-talk
Prev: Re: Suggestion on LVDT? Makarov, Oleg A. via Tech-talk
Next: Re: data format conversion Florian Feldbauer via Tech-talk
