1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Tech-talk Digest, Vol 14, Issue 462
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "Shen, Guobao" <[email protected]>
Date: Fri, 21 Aug 2020 17:28:34 +0000
Guobao, Oleg,
We use Resolute absolute encoders from Renishaw, which have up to 21m. Other absolute solution have longer range.
Incremental is also fine, but homing got us into trouble when system is coupled.
Kazimierz
From: Tech-talk <[email protected]> on behalf of [email protected] <[email protected]>
Sent: Friday, August 21, 2020 1:00 PM
To: [email protected] <[email protected]>
Subject: Tech-talk Digest, Vol 14, Issue 462
Send Tech-talk mailing list submissions to
        [email protected]
To subscribe or unsubscribe via the World Wide Web, visit
        https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
        [email protected]
You can reach the person managing the list at
        [email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. Re: Suggestion on LVDT? (Makarov, Oleg A.)
   2. data format conversion ([email protected])
   3. Re: data format conversion (Florian Feldbauer)
Message: 1
Date: Thu, 20 Aug 2020 20:09:21 +0000
Subject: Re: Suggestion on LVDT?
Message-ID: <[email protected]>
Content-Type: text/plain; charset="utf-8"
Hi Guobao Shen,
I suggest a different technology to be used for linear displacement
sensing: an optical linear encoders:
https://urldefense.com/v3/__https://www.celeramotion.com/microe/products/linear-encoders/compact/veratus-series-vi/__;!!P4SdNyxKAPE!WwcCP3rrG3b_Z4F4R19qGKFn_sUIMSYQDTaUalzr7oWfxr_EyIox4wdVx9p7qpmJ$
these provide resolutions down to 20 nm and up to 30 m measuring lengths.
Oleg Makarov
On 8/20/2020 2:40 PM, Shen, Guobao via Tech-talk wrote:
> Hi Community,
> Does anyone have a suggestion about an electronics on the LVDT?
> We, here at APS, are currently using North Atlantic NA7800 LVDT, and want to have a replacement.
> Appreciate if there is any suggestion a newer version of  electronics, especially VME module, as well as the EPICS driver availability.
> Thanks,
> Guobao
> Guobao Shen
> Controls Group Leader
> Accelerator Systems Division
> Advanced Photon Source Bldg. 401-C2268
> Argonne National Laboratory
> 9700 South Cass Avenue
> Argonne, IL 60439
> Office:  630-252-1614
> Email:  [email protected]<mailto:[email protected]>
Message: 2
Date: Fri, 21 Aug 2020 09:43:49 +0800
To: tech-talk <[email protected]>
Subject: data format conversion
Content-Type: text/plain; charset="gb2312"
Hello everyone,
I am using the stream device to gat data from a device, and have a problem about format conbersion.  I  hope to get some advice and will appreciate for your help.
I want to send data, such as "09", in hexademical format to the device.  the device will return  a float data %f.
Statements in the db file:
  recorrd(ai, "$(P)$(R)read")
        field(DESC, "read pressure")
        field(DTYP, "stream")
        field(INP, "@pressure.proto SendCommand(09)  $(PORT)")
        field(SCAN, "1 second")
Statements in the protocol file is like this:
SendCommand{
    out "\x\$1";
    in "%f";
when I run the st.cmd, an error occurs:
Hex digit expected after \x:  "\X""
if "09" is send directly, not as a variable "\$1":
SendCommand{
    out "\x09";
    in "%f";
everything goes well and I can get the returned %f correctly.
I wonder how can I send "09" as a variable?  How to change a variable in the record to be hexadecimal?
Thank you very much for any advice, I will try it and give feedback.
Bset wishes
Chunxia Yin
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20200821/fa28d947/attachment.html>
Message: 3
Date: Fri, 21 Aug 2020 17:00:00 +0200
To: "[email protected]" <[email protected]>, tech-talk
        <[email protected]>
Subject: Re: data format conversion
Message-ID:
        <[email protected]>
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Hey Chunxia,
you could try the following:
field(INP, "@pressure.proto SendCommand(9)? $(PORT)")
SendCommand{
 ??? out $1;
 ??? in "%f";
Without quotes, the variable is assumend to be the decimal value of one
byte, so it will send one byte with value '9' to your device, just like
"\x09" would do.
HTH,
Florian
Am 21.08.2020 um 03:43 schrieb yincx--- via Tech-talk:
> Hello everyone,
> I am using the stream device to gat data from a device, and?have a
> problem about format conbersion. ?I ?hope to get some advice and will
> I want to send data,such as "09", in hexademical format to the device.
> ?the device will return ?a float data %f.
> field(INP, "@pressure.proto SendCommand(09)? $(PORT)")
> SendCommand{
> ??? out "\x\$1";
> ??? in "%f";
> Hex digit expected after \x: ?"\X""
> SendCommand{
> out "\x09";
> in "%f";
> I wonder how can I send "09" as a variable? ?How to change a variable
> Bset wishes
> Chunxia Yin
Ruhr-Universit?t Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universit?tsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://urldefense.com/v3/__https://paluma.ruhr-uni-bochum.de__;!!P4SdNyxKAPE!WwcCP3rrG3b_Z4F4R19qGKFn_sUIMSYQDTaUalzr7oWfxr_EyIox4wdVx0j7aUoU$
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20200821/c4deeef9/attachment.html>
Subject: Digest Footer
Tech-talk mailing list [email protected]
End of Tech-talk Digest, Vol 14, Issue 462
Prev: Re: data format conversion Florian Feldbauer via Tech-talk
Next: CSS Phoebus spinner step size Pietryla, Anthony F. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
